Auto tranny not shifting!!! Please Help!!!
The problem is i can shift through park, neutral, reverse, and drive but when im in drive the tranny starts off in 2nd gear and it wont shift. also, when i put it down into 1st it will rev up freely like neutral. Any input is appreciated and thanks ahead of time for your help!
Modified by midnitesol at 3:15 PM 12/7/2007
get under the car and check your auto shifter cable or the bracket that holds it. The cable probably has some slack in it. That's why when you put it in D4 it's actually D2 which won't let you go past 2nd gear.
specialty
Honda CR-V & Element
Oct 16, 2012 05:37 AM
