Keep Blowing 10A cluster/taillight fuse
Old Dec 5, 2007 | 07:00 PM
aaronISthrowed's Avatar
Default Keep Blowing 10A cluster/taillight fuse
what could be the problem?
Old Dec 5, 2007 | 09:41 PM
ls19integra95's Avatar
Default Re: Keep Blowing 10A cluster/taillight fuse (aaronISthrowed)
lose wire somplace thats shorting that fuse out... check your wiring in the back to your tail lights...
Old Dec 5, 2007 | 11:06 PM
dcRay's Avatar
Have you done any electrical wiring recently? Look around, sounds like a short somewhere.
Old Dec 6, 2007 | 07:57 AM
Default Re: Keep Blowing 10A cluster/taillight fuse (dcRay)
I'll look in a little while, i did some wire tucking a while back with the drivers side headlight harness, maybe thats where it is.
Old Dec 6, 2007 | 02:48 PM
Tried today to find some loose wires or something but didn't find anything, any ideas on how to find the hot wire?
Old Dec 6, 2007 | 06:01 PM
1Point8DC2's Avatar
Check for water in your taillight housings.
Old Dec 6, 2007 | 06:20 PM
Default Re: Keep Blowing 10A cluster/taillight fuse (1Point8DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Point8DC2 &raquo;</TD></TR><TR><TD CLASS="quote">Check for water in your taillight housings.</TD></TR></TABLE>
There was mositure in my passenger side bumper lense, but i doubt enough to cause a problem.
Old Dec 6, 2007 | 06:33 PM
1Point8DC2's Avatar
By chance have you checked condition of your bulb sockets?
Old Dec 6, 2007 | 06:56 PM
Fern413's Avatar
Check to see if theres water in your taillights....if not then check your wiring...it could be a short to ground
Old Dec 6, 2007 | 09:16 PM
DAslammed's Avatar
Default Re: Keep Blowing 10A cluster/taillight fuse (Fern413)
lose wire from the cd deck did that to mines, blew 3 fuses until i found the lose wire touching the body, fixed
blowing fuses is a bitch
Old Dec 7, 2007 | 04:11 PM
Default Re: Keep Blowing 10A cluster/taillight fuse (DAslammed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAslammed &raquo;</TD></TR><TR><TD CLASS="quote">lose wire from the cd deck did that to mines, blew 3 fuses until i found the lose wire touching the body, fixed
blowing fuses is a bitch </TD></TR></TABLE>
Was it doing it to the tailight/cluster fuse?
Old Dec 7, 2007 | 04:40 PM
Ok got it working now, i messed with some wires behind the headunit and its working now.
Old Dec 31, 2007 | 05:30 PM
jerBEAR's Avatar
Thats great that you were able to fix that problem. Mine blew out today and I have already pulled out all bulbs in the back, the front corner light bulbs (for some reason, they do not turn on when the fuse is blown either), my cruise control light, my dimmer switch, the light in the glove box, the lights in the coin tray, the entire gauge cluster, as well as the harness for the air conditioner control. After all that, the fuse blows right when I turn the light switch. Hopefully tampering with some of the wires behind the radio will fix this damn problem.
Old Jan 16, 2008 | 05:38 PM
blackakkord's Avatar
interesting, there was a wire leading into my radio fuse.. i removed it, radio worked fine but the fuse to the parking/dash lights blew immediately. will try to remove radio tomorrow and see if it solves it like your case.. this is a big headache!!!
Old Jan 16, 2008 | 06:47 PM
Leo C's Avatar
Night Owl
Default Re: (blackakkord)
Your power ANT wire to teh headunit can blow this fuse if it's grounded. IE touching metal. A wire-nut or some electric tape should fix 'er right up.
Yeah Daybid
Aug 29, 2008 06:07 AM
Cheeech
Oct 28, 2005 11:29 PM
t0ekn3e
Aug 31, 2004 11:00 PM
stockegsix
Apr 4, 2004 03:16 AM
dc2lun
Feb 16, 2004 03:11 PM
