aem fuel rail and b&m fpr
Old Dec 5, 2007 | 03:24 PM
grjp1988's Avatar
Default aem fuel rail and b&m fpr
I have a b&m fpr and I just recieved my fuel rail in the mail. my ? is will the fpr bolt up to the aem or do I have to buy a aem adjustible because when I baught the car it didnt come with the stock fpr
sorry forgot to add that it is an aem high flow
Old Dec 5, 2007 | 04:19 PM
IN VTEC's Avatar
Default Re: aem fuel rail and b&m fpr (grjp1988)
It should bolt on just fine. There should be a pair of M6x1.00 threaded blind holes with a 1/8" NPT hole in between on one side to secure the FPR to the fuel rail.
If you don't have that, then you're going to need an universal FPR....Aeromotive, AEM, etc.
Old Dec 5, 2007 | 04:50 PM
Boosted_01 R's Avatar
Default Re: aem fuel rail and b&m fpr (IN VTEC)
Whats the intended use? turbo, all motor ? I would get a stock one, or just don't use the B&M. I would say use stock.........FTW as HT would say
It will work though. AEM uses stock FPR bolt pattern
Old Dec 5, 2007 | 05:22 PM
grjp1988's Avatar
pretty much fully built c5
Old Dec 5, 2007 | 05:23 PM
BlueR's Avatar
Default Re: (grjp1988)
it will bolt on just fine
Old Dec 5, 2007 | 05:34 PM
grjp1988's Avatar
thanks again
Old Dec 5, 2007 | 05:37 PM
Default Re: (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grjp1988 &raquo;</TD></TR><TR><TD CLASS="quote">pretty much fully built c5</TD></TR></TABLE>
sweet. I wouldn't take the chance with the B&M though, very bad rep, tends to fail a lot, and fluctuating fuel pressure.
AEM is a very good choice, if your looking for something with ruffy the same shape.
Old Dec 5, 2007 | 05:43 PM
Padawan's Avatar
Darth ModerVader
If it's not too late, I'd return the fuel rail and put the money towards something else. It will not benefit your setup.
Old Dec 5, 2007 | 06:39 PM
grjp1988's Avatar
btw its a fully built c5 with a zex 100 wet shot. i didnt add that it has nitrouse because i dont plan on using it but a couple times at the track other than that all motor
w0ng_sta
Oct 6, 2006 09:18 AM
smash fascism
Apr 10, 2005 01:03 PM
tub_sephiroth
Jun 22, 2004 08:12 AM
LSTEG96
Oct 30, 2003 08:18 PM
4bidden
Feb 5, 2002 06:44 PM
