which FPR?
Old Jan 30, 2002 | 03:25 PM
4bidden's Avatar
Default which FPR?
I've heard some people say that AEM's are crap and apparently their site says that you can only use their FPR with their fuel rail. I've also heard some stories about B&M's leaking. Anyone have any experience with either of these or can recommend one of these or another one?
[Modified by 4bidden, 12:26 AM 1/31/2002]
Old Jan 30, 2002 | 03:42 PM
laughinxxx's Avatar
New User
Default Re: which FPR? (4bidden)
Yes, you do have to buy the AEM fuel rail to use the AEM fpr. I have both and I am very happy with their quality. You can't use the AEM fpr with the Zex nitrous kit, though.
Old Jan 30, 2002 | 06:17 PM
wutangben's Avatar
Default Re: which FPR? (laughin2.2)
whoa, i didnt know any of that poo poo. good thing i never popped for any of that poo poo.
(omg, i typed poo poo instead of poo poo, this censorship bs is gettin to my head)
Old Jan 30, 2002 | 07:03 PM
laughinxxx's Avatar
New User
Default Re: which FPR? (wutangben)
You have to use a B&M fpr for the zex kit.
Old Jan 30, 2002 | 07:28 PM
Diversion's Avatar
You guys are smoking crack, you can use the AEM FPR without the AEM Fuel Rail.. I have the AEM FPR on my stock fuel rail on my car right now, NO PROBLEMS with it..
I mean, there's absolutely NOTHING wrong with the AEM FPR, only that it costs like 2 times as much as a B&M FPR.. both are good, just some people like name brand poo poo.
Jay
Old Jan 30, 2002 | 08:15 PM
wutangben's Avatar
Default Re: which FPR? (Diversion)
ok, i was gonna say. i never knew that poo poo, didnt think it was true
Old Jan 30, 2002 | 09:28 PM
laughinxxx's Avatar
New User
Good for you. I hope you don't get any leaks. http://www.preludeparts.com/cgi-bin/...roduct=AEM_FPR
Edit: Here's another one. http://coximport.com/aem/fuelapps.html
Look at the bottom of the Honda section.
[Modified by laughin2.2, 10:31 PM 1/30/2002]
[Modified by laughin2.2, 10:32 PM 1/30/2002]
Old Jan 30, 2002 | 09:34 PM
schwett's Avatar
New User
wow. AEM says you need their fuel rail for the h22 fpr... but not for the b series ones. so basically they're full of it?
maybe i could trouble you to take a pic of it... i'd like to get one to replace my stock+b&m but there's not a lot of room behind the rail in my application. (sc in the way)
Old Jan 30, 2002 | 10:46 PM
976's Avatar
976
New User
Default Re: which FPR? (schwett)
If I read "poo poo" agian...
Anyway, B&M Command flo and FPG. Great accuracy, great price, easy adjustment. Nuff said...
[Modified by w00t!, 7:46 AM 1/31/2002]
[Modified by w00t!, 7:47 AM 1/31/2002]
Old Jan 31, 2002 | 08:46 AM
schwett's Avatar
New User
Default Re: which FPR? (w00t!)
the problem with the b&m is that since it doesn't replace the stock fpr, you will never be able to lower the pressure below what the really small orifice in the stocker allows. for those of use with bigger fuel pumps, it sucks. the only workaround is drilling a hole in the damn thing. if the AEM works on the stock fuel rail i'm there in a second!
Old Feb 1, 2002 | 06:31 PM
Diversion's Avatar
Laughin: That really sounds like a sales gimmick to get you to spend more money while purchasing the FPR.. I've been using the AEM FPR on my stock rail for almost a year now, and no leak problems.. I mean, if I were leaking, I would assume I would get nasty weird power surges and or crappy gas mileage.. I am ordering a AEM Fuel rail soon, and i'll check to see if there's any leaks on the stock rail.. all of that is news to me..
One apparently thing I noticed after the install of the AEM FPR is that right after cranking up and driving.. the car will hesistate and act like it's not getting any fuel the first 30 seconds of driving, but after that it's ok.. I assumed that it was the pressure increase causing this problem, although a leak could very well cause this too.. but I get excellent gas mileage, like 30 miles to the gallon on a H22A, which is excellent..
Update: Looked around for information regarding less, and aparently there's a slight problem with using the AEM FPR on the stock Prelude fuel rail.. Like I said, i've been using the AEM FPR on my Fuel rail for almost a year, could be why my car acts funny after cranking up on it.. Apparently I need to order a AEM Fuel rail right away before I cause myself some major problems, don't wanna start a fire under the hood.
Update: Found out the reason why the FPR doesn't fit on the stock Prelude fuel rail... it's not because it can't make a seal.. it's because the butterfly diaphragm is in the way and blocks you from being able to fit the AEM FPR in that location, being that it's much larger than the stock FPR. Soooo.. You CAN use the AEM FPR on the Prelude, however, you gotta unbolt the diaphragm and swing it down a bit to provide enough clearance to fit the AEM FPR on the rail.. The secondaries on the intake manifold still work fine after doing this.. but the AEM FPR does bolt onto the stock rail fine..
Jay
[Modified by Diversion, 10:52 PM 2/1/2002]
[Modified by Diversion, 1:22 AM 2/2/2002]
Old Feb 2, 2002 | 04:44 AM
SlickTech's Avatar
If your going to spend the cash on an an AEM why don't you spend a little extra and get a Paxton or SX. This will give you the option of adding a fuel pressure gauge right off the regulator. It's obviously not the best choice if cost is the main isssue or if you are trying to match other components you already have though. This is the route I would take if you are going to be adding some major hp later and is not hard to fit with an aftermarket fuel rail.......just another route to go.
Old Feb 2, 2002 | 07:06 AM
JG Luder's Avatar
Default Re: which FPR? (SlickTech)
Yeah, I can't turn my pressure below 43psi on my B&M. Maybe its that Walbro 342 in my tank........................
My next one will probably be a Paxton.
JG- who thinks it's about time he goes and gets his Lude back up and running
Old Feb 2, 2002 | 08:13 AM
3gLudeH22A's Avatar
Damn!!! Now i gotta get rid of my AEM FPR now. Hey laughin, how come you cant use the FPR with the ZEX system???????
Old Feb 2, 2002 | 02:35 PM
4bidden's Avatar
Default Re: which FPR? (3gLudeH22A)
which B&M fits the h22?
Old Feb 2, 2002 | 02:50 PM
laughinxxx's Avatar
New User
A guy on SHO's nitrous forum, aka where I was schooled in the black art of nitrous, tried using one with his Zex kit and he kept busting the diaphragm in the fpr. He ended up giving up on it after the third or fourth diaphragm blew and bought a NOS kit.
Old Feb 2, 2002 | 07:11 PM
Diversion's Avatar
AEM's Fuel Rail has the option of using a Fuel Pressure Gauge.. that's why AEM didn't put this option on their FPRs.
Jay
Old Feb 3, 2002 | 07:37 AM
SlickTech's Avatar
I understand what you are saying but there are other choices besides an AEM fuel rail. STR has them too. Just giving some options....that's all.
Old Feb 3, 2002 | 08:36 PM
4bidden's Avatar
once again....which B&M fits the h22? i cant find it anywhere.
Old Feb 3, 2002 | 08:41 PM
schwett's Avatar
New User
the one that says civic / crx / integra / nsx : bmm-46057
part of the install involves sawing in half your stock fpr, so there's no going back.....
Old Feb 3, 2002 | 09:58 PM
4bidden's Avatar
and i take it the gauge is universal?
ive never changed the fuel filter in my lude....where is it located? i dont want to mount a fuel press gauge on it if i wont be able to see it.
Old Feb 3, 2002 | 10:10 PM
laughinxxx's Avatar
New User
You can see the gauge just fine.
Old Feb 4, 2002 | 07:41 AM
DirtyLude's Avatar
The 5th Gen has the fuel filter in a different location. In an poo poo makes it difficult to change the oil filter with the B&M gauge on. You can use a fuel line to extend it out if you still want this option.
EDIT: I can't say 'SH', and then 'it' even with a space inbetween without this crappy curse filter changing it to 'poo poo'. Where it's says 'poo poo' up there, replace it with 'SH model it'.
[Modified by DirtyLude, 8:42 AM 2/4/2002]
Old Feb 4, 2002 | 04:27 PM
wutangben's Avatar
Default Re: which FPR? (DirtyLude)
what the hell is up with the censorship on this forum? is this supposed to be a G-rated forum or something? i dont think many kids visit here, considering in most states you have to be at least 16 to drive. let alone afford a prelude, or nice car
uckfay ensorshipcay
Old Feb 4, 2002 | 06:06 PM
976's Avatar
976
New User
uckfay ensorshipcay
Hey, it's better than superhonda.org - haha, that place is a joke!
