losing fluid in the hydralic clutch cylinder
Old Dec 5, 2007 | 03:43 AM
ej1-usdm's Avatar
Default losing fluid in the hydralic clutch cylinder
hey guyz. i need some advice or help.. one time i was driving my civic to work, all of a suddenly the clutch didnt wanna go in. so i went to go check an i was out of hydraulic fluid. when i add more, everything works fine, ...as i drive it again, same thing happen. so i bleed it over an over again,,, so i got fed up wid it, an went to go purchase a new clutch slave cylinder, an that fix all the problem.... like 4 to 5 days later.. i pop open my hood, due to oil change, the hydraulic fluid is all out, im like wtf,,, i check ever no leaks,.... an im all out of ideas. any body ?>????? got thee answer. an advice,>>??? would b appreciated
Old Dec 5, 2007 | 04:03 AM
tpr's Avatar
tpr
Default Re: losing fluid in the hydralic clutch cylinder (ej1-usdm)
Gennerally you replace the master and slave cylinders at the same time as they wear out together. Check your clutch master cylinder. I bet its leaking down the firewall.
WillyD
Transmission & Drivetrain
Oct 1, 2011 10:04 PM
patrick4588
Aug 31, 2008 05:58 PM
GraphiteMW
Mar 25, 2007 09:26 AM
malubawla
Oct 16, 2005 04:16 PM
suavea82
May 20, 2003 01:27 PM
