crower rod issue?????
hey guys im building my mottor right now and have run into a prob. any one used the crower rods and there build. i have a d17a2. is teh crower rod shorter than the stock rod?my crower rods are all shorter an di wanted to know if that is how it is suppose 2 be..
I never measured, but if you bought D17 rods and the requisite aftermarket pistons it works just fine.
Crower lists the length of their rod on the website, you'd have to measure the stocker and just compare.
bioler when u installed ur rods u had to notch them right??? my builder installed them an dhe said they werent even hitting the sleeves. and i have the fi rods from crower only mak eone model if im correct
You have to notch the block. The tops of the rod caps will hit the sides of the crank case if you dont. Post the part number of the rods you got.
you can see in there where material was removed for clearance
Modified by Boilermaker1 at 2:45 PM 12/5/2007
yes i know that what im saying is teh rods i have are shorter in height to my stock rods shouldnt they be teh same height? ithere at teh shop right now an di dont have them on hand
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Curiouz_G »</TD></TR><TR><TD CLASS="quote">most of the time
The bottom ends dont break. They make SOOOOOOO much power that the headgasket cant hold it.
</TD></TR></TABLE>The bottom ends dont break. They make SOOOOOOO much power that the headgasket cant hold it.
if they're a hair shorter,what issue would it cause? The pistons need to be below the deck, which they will be. Worst comes to worse, the compression is a hair lower that what the pistons are stated to be. Stroke is dictated by the crank throw, and you need to tune it afterwards anyways.
Just put the damn thing together and stop thinking about it.
It doesnt really help that you're going off what a shop is telling you, and you havent told us where the measurements are being taken from.
You'd have a big problem if they were longer. But this does nothing to effect anything of consequence. If you're so worried.... do yourself a big favor, get off the message boards, pick up a phone and CALL CROWER
also i was weary because it dosent look like i have to notch teh sleeves for the crower rods. and almost everyone who installed them had 2 notch there sleeves...but couple people told me they have herd of no nothcing being needed. i just dont understand how some have to and some dont
