bleeder screw???
Old Dec 4, 2007 | 12:23 PM
juniestyle's Avatar
Default bleeder screw???
00 integra type r....where in the hell is the bleeder screw for the cooling sytem???
cant find it no where...let me know...thanx!!!!
Old Dec 4, 2007 | 12:43 PM
Lubo_25's Avatar
Default Re: bleeder screw??? (juniestyle)
try the thermostat housing the h/f motors have them there...
Old Dec 4, 2007 | 01:04 PM
juniestyle's Avatar
Default Re: bleeder screw??? (Lubo_25)
yea i looked over there but see nothing?!?!
Old Dec 4, 2007 | 01:05 PM
juniestyle's Avatar
anyone??
Old Dec 4, 2007 | 06:41 PM
juniestyle's Avatar
please someone help me
Old Dec 4, 2007 | 08:44 PM
bschulz's Avatar
Your radiator cap. Make sure your heater valve is open (max heat).
Old Dec 4, 2007 | 09:35 PM
juniestyle's Avatar
Default Re: (bschulz)
so basically run the engine with the cap off and the heat on max?!?!
Old Dec 4, 2007 | 10:24 PM
bschulz's Avatar
Yes. Allow the thermo to open (engine at running temp) make sure your res. is full and massage the lines if needed to pump out any air pockets.
Old Dec 6, 2007 | 07:55 AM
b18LS's Avatar
Yes, the newer integra dont have that screw. My DA did for what I can remember, btut eh DC doesnt. Take the cap off, and keep an eye on it until the bubbling stops.
Old Dec 6, 2007 | 09:39 AM
hatchling37's Avatar
Default Re: (b18LS)
Squeeze your lower hose, too, to help burp the system.
Old Dec 6, 2007 | 04:08 PM
mmuller's Avatar
Mad Scientist
Default Re: (hatchling37)
yep, cap off and check after it cools
who uses bleed screw anyways... type arrr dont have them because less weight..lol
Old Dec 7, 2007 | 03:45 PM
StorminMatt's Avatar
Default Re: (mmuller)
Here's the BEST way to fill a cooling system without a bleeder screw. Pull off the upper radiator hose from the engine, and hold it on the nipple in such a way that you create a small opening between the end of the hose and the nipple. Fill the radiator, andstop when water comes out of this opening. Then reconnect and clamp the hose.
Slammed97coupe
Jan 8, 2017 07:19 AM
jdm_obsession88
12
Sep 12, 2010 01:19 PM
Anakyst
Feb 9, 2007 08:25 AM
DriveSlowHomie
Dec 7, 2006 06:57 PM
DFW
Jan 29, 2005 07:57 AM
