Throttle body problems
Hi, i have a supercharged civic d16y8, cams, ported head, oversized valves, aem CAI.... etc. So i had change my oem TB for a 70mm skunk2 TB. Now the idle speed is 2500 rpm and over, i had tested the IAC, TPS and all of them are ok, the idle screw it's totally closed, the TPS it's outputting 0.5 V in close position. When i put the oem TB back the problem dissapear.
What do you know about this?
you might have a vacumm leak. spray some carb cleaner around the area and see if you see/hear any engine change. if so thats where the leak is
criticallistenp
45
Jun 18, 2023 08:13 PM
longfellahh
Oct 16, 2008 02:35 PM
