*** Dash Question ... Where does this plug go?!?!
Old Dec 4, 2007 | 09:54 AM
BUCK_NASTY's Avatar
Default *** Dash Question ... Where does this plug go?!?!
I took my dash out the other day...and uhh I cant seem to find where to plug in one of the 4 plugs in the pics below...The first pic gives you an idea of where they go, 3 of the 4 were just pluged into the fuse box... I cant find where the long(hanging down the farthest) grey one goes to, please help!!!
Edit: This dash is not from a gsr, and the car that its going into is...Could this plug not be used for the gsr's??
Also I traced that plug to a plug that goes to the cluster(see pics below)...where does this plug go to the fuse panel at??
Close up of the 4 plugs, I need to know where the long grey one goes (the one with the longest wires)
OK I traced that plug to a plug that goes to the cluster I put a red circle around the one it goes to( kinda hard to see the red but its there)
Modified by BUCK_NASTY at 10:22 PM 12/4/2007
Modified by BUCK_NASTY at 12:56 PM 12/5/2007
Modified by BUCK_NASTY at 12:57 PM 12/5/2007
Modified by BUCK_NASTY at 12:59 PM 12/5/2007
Old Dec 4, 2007 | 09:57 AM
AWD Terror's Avatar
Default Re: *** Dash Question ... Where does this plug go?!?! (BUCK_NASTY)
Put it in your car, and you should be able to see it.
I'm not sure where it goes, but it has to be close to the fuse box
Old Dec 4, 2007 | 09:58 AM
BUCK_NASTY's Avatar
Default Re: *** Dash Question ... Where does this plug go?!?! (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">Put it in your car, and you should be able to see it.
I'm not sure where it goes, but it has to be close to the fuse box</TD></TR></TABLE>
...yeah that was the first thing I tried....Cant see anything, thats why I took the time to post this...
Old Dec 4, 2007 | 10:08 AM
AWD Terror's Avatar
Does it reach to the steering column?
Is it for cruise control?
There is something that plugs into the seperate dash peice by your knees.
Do you have a repair book for it?
It will tell you step by step removal. I take a picture of my car tonight for you if you don't figure it out.
Old Dec 4, 2007 | 10:12 AM
BUCK_NASTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">Does it reach to the steering column?
It will tell you step by step removal. I take a picture of my car tonight for you if you don't figure it out.</TD></TR></TABLE>
all the plugs on the dash up there are pluged in (sunroof, dim, cruise control)... there is a little grey plug and a little green one that goes by your knees I think, but still nowhere for this plug...I tried my best to follow the wires and they might go to one of the plugs on the back of the cluster(not sure tho)
Old Dec 4, 2007 | 10:14 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUCK_NASTY &raquo;</TD></TR><TR><TD CLASS="quote">
all the plugs on the dash up there are pluged in (sunroof, dim, cruise control)... there is a little grey plug and a little green one that goes by your knees I think, but still nowhere for this plug...I tried my best to follow the wires and they might go to one of the plugs on the back of the cluster(not sure tho)</TD></TR></TABLE>
You do not need to touch the cluster to get the dash out.
I do believe that there's four plugs into the fuse panel. I remeber taking that grey one towards the passanger side. That's why I'm gonna go with steering wheel.
Old Dec 4, 2007 | 10:21 AM
BUCK_NASTY's Avatar
I do believe that there's four plugs into the fuse panel. I remeber taking that grey one towards the passanger side. That's why I'm gonna go with steering wheel.</TD></TR></TABLE>
I know you dont have to touch the cluster...but I followed the wires from this plug and I think they went to one of the plugs on the back of the cluster, like I said i could be wrong tho
Old Dec 4, 2007 | 10:34 AM
AWD Terror's Avatar
Online service manual:
http://powweb.hondahookup.com/...p.pdf
Make sure you have four plugs in the fuse box. Then make sure you have all the plugs in the steering column.
Look to see where the wire is coming from.
Old Dec 4, 2007 | 12:50 PM
krytoi's Avatar
thats for a cluster
Old Dec 4, 2007 | 02:10 PM
BUCK_NASTY's Avatar
Default Re: (krytoi)
Could it be that the dash is not from a gsr and I am putting it into a gsr?? Because There is nowhere to plug it in that I can see at all....HELP
Old Dec 4, 2007 | 03:46 PM
berb_15's Avatar
Default Re: (BUCK_NASTY)
Is it by any chance the plug that plugs into the button to turn the maintenance required light off on the panel under the steering wheel?? It's been a while since I had my dash out but that's one more thing to check...
Old Dec 4, 2007 | 03:48 PM
berb_15's Avatar
Default Re: (berb_15)
now that I look closer I think it's too big and too many wires for that...
Old Dec 4, 2007 | 04:11 PM
DC2Hedi's Avatar
i agree with awd http://www.hondahookup.com/man...p.pdf get the manual and look it up we are not all under your dash
Old Dec 4, 2007 | 06:17 PM
BUCK_NASTY's Avatar
Default Re: (DC2Hedi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2Hedi &raquo;</TD></TR><TR><TD CLASS="quote">i agree with awd http://www.hondahookup.com/man...p.pdf get the manual and look it up we are not all under your dash</TD></TR></TABLE>
Why does this site even exist if all anyone says is "Look it up"... ... ... wow, it should look the same under any gsr, so I was hoping someone might be so kind as to look...THANKS FOR NOTHING
Old Dec 4, 2007 | 08:50 PM
K2sInteg98's Avatar
i think it might be for the cluster. I kno some years have 3 plugs for the cluster while some have 4. maybe yours only has 3 and the teg that the dash came out of had 4 for the cluster.
Old Dec 4, 2007 | 09:23 PM
VTEC_PRODUCTION's Avatar
Why does this site even exist if all anyone says is "Look it up"... ... ... wow, it should look the same under any gsr, so I was hoping someone might be so kind as to look...THANKS FOR NOTHING </TD></TR></TABLE>
wow chill out man...not all of us take out our dash...when i took the dash out of my civic no wires were attached that i can remember...you should be able to take a look after you get the dash in there and figure it out.
Old Dec 4, 2007 | 09:51 PM
CeReal's Avatar
Default Re: (VTEC_PRODUCTION)
my first thought was ac,heat,fan controls.
then hazard and defrost.
Old Dec 5, 2007 | 04:21 AM
BUCK_NASTY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION &raquo;</TD></TR><TR><TD CLASS="quote">
wow chill out man...not all of us take out our dash...when i took the dash out of my civic no wires were attached that i can remember...you should be able to take a look after you get the dash in there and figure it out.</TD></TR></TABLE>
hum..if you take the time to read THEN post you will see that I already put the dash in and I still dont see where it goes...but im sure Ill figure it out sometime
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CeReal &raquo;</TD></TR><TR><TD CLASS="quote">my first thought was ac,heat,fan controls.
Ill check into that thanks
Old Dec 5, 2007 | 04:36 AM
BUCK_NASTY's Avatar
Default Re: (K2sInteg98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K2sInteg98 &raquo;</TD></TR><TR><TD CLASS="quote">i think it might be for the cluster. I kno some years have 3 plugs for the cluster while some have 4. maybe yours only has 3 and the teg that the dash came out of had 4 for the cluster. </TD></TR></TABLE>
Im going to get the harness apart and follow the wires up to see exactly where they go...If they do go to the cluster, and like K2sInteg98 said some have 4 for the cluster but if mine only has 3, what do you do about that...Has anyone had this happen??
thanks
Old Dec 5, 2007 | 08:59 AM
BUCK_NASTY's Avatar
bump
Old Dec 5, 2007 | 11:39 AM
AWD Terror's Avatar
Default Re: (CeReal)
</TD></TR></TABLE>'
None of these. They are too far away.
I looked under my dash and found four plugs into the fuse panel. There is one in the same area as yours, and it hooked into the steering column.
GL man
stinkypinky1011
Honda CR-V & Element
Mar 28, 2016 05:02 PM
mortificationrock
11
Dec 31, 2011 01:08 PM
Dragger817
Jul 7, 2006 08:40 PM
White cracker yeehaa
Nov 8, 2005 05:27 PM
boosted_zc
Aug 6, 2005 10:02 PM
