Number 3 and 2 cylinders are dead
Old Dec 4, 2007 | 06:29 AM
civic_driver_85's Avatar
Default Number 3 and 2 cylinders are dead
Ok i just bought a 95 honda civic cx. apon charging that batery i got it to start up but its only running on the number 1 and 4 cylinder. the number 3 and 2 are getting spark the cap and wires are in good shape. i cant figure it out and was wounder if you could give me some hints to what it would be. thank you.
Old Dec 4, 2007 | 06:51 PM
SEATownboi08's Avatar
Default Re: Number 3 and 2 cylinders are dead (civic_driver_85)
Did you check the spark plugs?? Is firing order right? The spark plugs could be fouled but most likly you have dead cylinders=(
Old Dec 4, 2007 | 06:53 PM
SOHC_4dr's Avatar
also check the internal posts on the distributor cap to see if they are carboned up or broken
Old Dec 4, 2007 | 07:59 PM
djessenz's Avatar
Default Re: (SOHC_4dr)
Well, once VTEC kicks in it's like you have 8 cylinders. So 8 cylinders minus 2 cylinders means you are still driving a 6 cylinder during VTEC . Any CELS?
Old Dec 4, 2007 | 08:03 PM
nicko360's Avatar
* B A N N E D *
well maybe you should have a funeral for them
Old Dec 4, 2007 | 08:14 PM
sRa-ah muy keol 7126's Avatar
* B A N N E D *
Default Re: Number 3 and 2 cylinders are dead (nicko360)
Nicko, your car's are peices of ****. And why would you trade the Si clone for a bagged s-10?
Old Dec 4, 2007 | 09:59 PM
inline4wHORE's Avatar
Default Re: Number 3 and 2 cylinders are dead (sRa-ah muy keol 7126)
check the injectors make sure there working
Old Dec 5, 2007 | 05:29 PM
nicko360's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sRa-ah muy keol 7126 &raquo;</TD></TR><TR><TD CLASS="quote">Nicko, your car's are peices of ****. And why would you trade the Si clone for a bagged s-10?</TD></TR></TABLE>
do i know you
Old Dec 5, 2007 | 07:25 PM
EJ8tunerman's Avatar
Make sure you have 2 and 3 spark plug wires in the right order, meaning they are not swapped on the cap or on the actual plugs &gt; OHM 2 and 3 spark plug wires &gt; Use good known plugs gapped to spec &gt; Compression test cyl 2 and 3 &gt; Use a noid light to test 2 and 3 injectors &gt; Hook a fuel pressure gauge and do an injector test on 2 and 3. This simple flow chart should do something for you.
Old Dec 6, 2007 | 08:37 PM
Default Re: Number 3 and 2 cylinders are dead (EJ8tunerman)
ya we checked the compression and fuel pressure and all seemed fine so i bought a d16y7 block with a v-tech head and just gonna swap it into their. and i got a real good deal on it so thanks for the advice. and have a good day.
Modified by civic_driver_85 at 6:35 AM 12/8/2007
Pudnite
Feb 11, 2018 04:46 PM
f20beme
Apr 21, 2015 09:09 AM
f20beme
Apr 16, 2015 04:27 PM
94.Si.Lude
Mar 20, 2009 09:39 PM
civicxxman
Apr 27, 2008 01:52 PM
