Seeking guidance from engine builders
Old Dec 3, 2007 | 07:54 PM
LstCivic's Avatar
Default Seeking guidance from engine builders
I am going to attempt to build my first motor (b18a1). I was wondering what materials you guys have read or used to build a motor. I am planning on ordering a 91 integra service manual from Helminc.com to get all specs and tolerances unless you guys know of a better place.
Also how does turbocharging a motor affect ring gap (tighter gap more gap?)
Thanks for any guidance
Old Dec 3, 2007 | 10:30 PM
wed3k's Avatar
from what i understand, you want more ring gap for forced induction and thats because of the heat induced?
micrometer = journals of crankshaft, pistons so machine shop to hone to size.
bore guage = main bore housing, possibly rod bore housing and the cylinder bore size when boring/honing
im sure you have a set of feeler blades and also get a flat long block of wood for sanding decks and removing gasket material.
Old Dec 4, 2007 | 04:41 PM
LstCivic's Avatar
Default Re: (wed3k)
So how much? On the more open side of oem specs? Also won't the machine shop take care of lining everything up if out of place (as far as line honeing checking cylinders for correct bore (81.5 bore).
Old Dec 4, 2007 | 07:53 PM
bschulz's Avatar
You want a wider ring gap to allow for extra expansion caused by extreme temps.
If you have a reputable shop that you trust, have them overbore, align hone, big end hone, and polish the crank for you. They may size everything for the same cost, or slightly more, which would still be a lot cheaper and more accurate then doing it yourself (for the first time).
As far as bearing selection goes your looking for .001-.002. If you ask around most builders will recommend .0015 for 1,2,4,5 and .0017 on 3.
Also, don't forget you can download almost any honda/acura SM from many sites for free.
Old Dec 5, 2007 | 03:04 PM
LstCivic's Avatar
Default Re: (bschulz)
Thanks for your help and guidance. I will go look for a service manual now.
Old Dec 5, 2007 | 04:06 PM
LstCivic's Avatar
Default Re: (LstCivic)
I am currently getting ready to order the oil pump, gaskets, water pump etc. and I noticed for the part # for the oil pump it is 15100-P72-A01. Doesn't the P72 designate Gsr? I heard from some people that 96+ oil pumps are better so I am looking up an oil pump for a 97. Also does the P75 badging have any difference over PR4 when ordering engine parts?
Old Dec 6, 2007 | 12:50 PM
integrag's Avatar
p72 is gsr and p75 is ls...the gsr oil pumps are better because they are made to compensate for vtec
Old Dec 8, 2007 | 05:26 PM
integrag's Avatar
if its obd1 the obd2 are all the same
Yuta
Aug 3, 2016 06:18 PM
raverx3m
Jun 10, 2014 10:55 AM
cehcivic15
Jan 18, 2010 04:23 PM
Yambor
Apr 29, 2005 10:55 PM
1.8EG-T
May 16, 2002 12:42 AM
