Help with installing an si radio in my eg
Old Dec 3, 2007 | 07:08 PM
xMRDR3Wx's Avatar
Default Help with installing an si radio in my eg
I had to go and get the harness from a 99 civic for the back of the SI radio, and another harness to conect that harness to the one in my hatch I found a couple of wiring diagrams but I cant get the info I need can some one provide me with a radio wiring diagram to help me get this working right I greatly appreciate it
Old Dec 3, 2007 | 07:15 PM
xMRDR3Wx's Avatar
up
Old Dec 3, 2007 | 07:17 PM
DCSportEJ1Civic's Avatar
Default Re: Help with installing an si radio in my eg (xMRDR3Wx)
visit your local honda dealer. they will give it to you for free.
Old Dec 3, 2007 | 07:34 PM
xMRDR3Wx's Avatar
Default Re: Help with installing an si radio in my eg (DCSportEJ1Civic)
I dont need the code I need a wiring diagram
Old Dec 3, 2007 | 08:42 PM
xMRDR3Wx's Avatar
bump
Old Dec 3, 2007 | 09:18 PM
BlueIntegraBoy's Avatar
Default Re: (xMRDR3Wx)
So you got radio harness for the 92-95 Civic and reverse harness for the Si radio? Just color match the wires, if you did. This is what I did to make a plug and play jumper harness.
Old Dec 3, 2007 | 10:44 PM
xMRDR3Wx's Avatar
^ yeah but ide hate to hack the integra harness for a radio I have the harness you buy when your installing an aftermarket radio to use so I didnt have to cut the harness and I found a diagram that shows what factory wire connect to the aftermarket harness. I connected,and soldered the power and ground but when I go to hook it up nothing Im getting power cause I checked it with a test light, and the radio was working perfect when i pulled it out a couple of days ago
Old Dec 3, 2007 | 11:38 PM
deadline's Avatar
they are not plug and play ?
Old Dec 4, 2007 | 12:21 AM
Default Re: (deadline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">they are not plug and play ?</TD></TR></TABLE>
Nope, the Si uses the fatter blue plug, while the 92-95 Civic uses the longer grey plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xMRDR3Wx &raquo;</TD></TR><TR><TD CLASS="quote">^ yeah but ide hate to hack the integra harness for a radio I have the harness you buy when your installing an aftermarket radio to use so I didnt have to cut the harness and I found a diagram that shows what factory wire connect to the aftermarket harness. I connected,and soldered the power and ground but when I go to hook it up nothing Im getting power cause I checked it with a test light, and the radio was working perfect when i pulled it out a couple of days ago</TD></TR></TABLE>
What I did to avoid hacking up the factory radio harness was to buy...
and
Match the wire colors, solder the wires, and plug and play.
Did you pop a fuse while soldering?
Here's a factory harness diagram: http://www.installdr.com/Harnesses/HA-Wiring.pdf
Old Jan 3, 2008 | 10:23 AM
fc3srx729's Avatar
those connectors will help alot...
MilesG
Audio / Security / Video
18
Dec 28, 2008 05:29 PM
hondaz6lx
11
Dec 10, 2007 12:02 PM
CivicRider011
Dec 10, 2006 07:07 PM
GoodGasMileage
May 21, 2003 08:44 AM
Jonathan_ED3
Apr 17, 2002 06:28 PM
