Will a P28 ecu run a b18b1?
Old Dec 3, 2007 | 06:27 PM
HondaVTEC1993's Avatar
Default Will a P28 ecu run a b18b1?
I recently put a b18b1 engine in my 90 honda civic hatchback. Well, since later down the line ill be going lsvtec, ive got a p28 ecu that im using. It is boosted and i want to know if the p28 will be fine to run the ls. I was worried about the whole vtec/nonvtec difference of the computer/engine. I have driven the car and it seems fine, but it is throwing a cel for vtec. The p28 is chipped and will be tuned on CROME. What do i need to do to get it running right so i dont mess the motor up?
Old Dec 3, 2007 | 07:28 PM
JDMeg95's Avatar
Default Re: Will a P28 ecu run a b18b1? (HondaVTEC1993)
if you get it tuned to remove vtec i think it works but if not your car will run like ****......i had a p28 on my ls and it ran horrible so i sold the p28 for 100 and bought a p75 ( ls ecu) for 30 and pocketed the rest make a huge difference , save the p28 until you do your ls vtec conversion
Old Dec 3, 2007 | 08:47 PM
DC4KiD's Avatar
Default Re: Will a P28 ecu run a b18b1? (JDMeg95)
It'll work just fine, just have a tuner disable the VTEC.
Old Dec 4, 2007 | 05:29 AM
Default Re: Will a P28 ecu run a b18b1? (DC4KiD)
ok, and from that just tune the fuel and everything with what is best for the car?
(i dont know anything about this, )
Old Dec 4, 2007 | 05:44 AM
splitime's Avatar
Either do some homework time on pgmfi.org or pay a tuner for a full tune.
I'd personally leave vtec on... and just get extra map resolution for kicks. If the cells before/after vtec match smoothly, the "engagement" won't be noticeable.
Old Dec 4, 2007 | 06:06 AM
Default Re: Will a P28 ecu run a b18b1? (splitime)
oh, i wont be tuning it, haha the car would blow up if i did, but me and the guy that is tuning it wanted to make sure the p28 would run a ls ok
Old Dec 4, 2007 | 06:09 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaVTEC1993 &raquo;</TD></TR><TR><TD CLASS="quote">oh, i wont be tuning it, haha the car would blow up if i did, but me and the guy that is tuning it wanted to make sure the p28 would run a ls ok</TD></TR></TABLE>
A chipped and tuned p28 will run it just fine. You just have a dual map setup and the ability to trigger a solenoid.
So you can leave vtec on, and use the dual maps to get double the # of tuneable cells. Or u can turn it off and run off a single map.
You could also use the vtec activation to trigger something else, like water injection or n20 or flame thrower etc
Old Dec 4, 2007 | 06:39 AM
new question, what if i get a p75 to run the ls right now, and since im going to be lsvtec later, chip that for vtec? Is that even possible?
Old Dec 4, 2007 | 06:56 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaVTEC1993 &raquo;</TD></TR><TR><TD CLASS="quote">new question, what if i get a p75 to run the ls right now, and since im going to be lsvtec later, chip that for vtec? Is that even possible?</TD></TR></TABLE>
It can be chipped and converted to a vtec spec ecu.
Old Dec 4, 2007 | 07:13 AM
is that something that can be done with CROME or the chip itself?
Old Dec 4, 2007 | 07:18 AM
splitime's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaVTEC1993 &raquo;</TD></TR><TR><TD CLASS="quote">is that something that can be done with CROME or the chip itself?</TD></TR></TABLE>
Ecu needs to be chipped for normal tuning usage. There is a 2nd set of chipping/modification that needs to be done to the ecu itself to use vtec on that ecu. It basically converts the board to the same specs as the p28 ecu.
Easiest to get both done at the same time by whoever you have chip the ecu.
Once chipped and converted the tuner can turn on/off vtec within the code itself.
Old Dec 4, 2007 | 07:22 AM
are you a tuner or something? im asking because if the guy cant do it ill need to send it to someone who can chip it haha
Old Dec 4, 2007 | 07:46 AM
electron_si's Avatar
pm'd you about this.
Old Dec 4, 2007 | 08:51 AM
replied
Old Dec 5, 2007 | 11:00 AM
I've decided to go with a P75 for now, then have it chipped for the head later. Anyone got one for sale?
Old Dec 5, 2007 | 12:11 PM
93turbo16's Avatar
Default Re: (HondaVTEC1993)
I would honestly say just pick up a P28 or vtec spec ecu at first. Then you won't have to upgrade or do anything when you put the vtec head on. The obd1 P28 can basically run any combination of MPFIOBD0/OBD1/pre-coil pack obd2 motors. It just has to be programed accordingly.
Old Dec 5, 2007 | 12:27 PM
the only thing i was thinking of anyway is the fact that the p28s go for like 80-100 and the p75s go for like 50, and even with chipping the p75 will be less than the stock p28 (am i right? lol) But the thing is i dont even know when ill be getting that head, it might take me til this time next year
Old Apr 26, 2018 | 06:47 PM
Hellabrok3's Avatar
Curious to know How would one activate the 2nd map to sell you said it best, falls thrower
Old Apr 26, 2018 | 06:48 PM
Hellabrok3's Avatar
Old Apr 26, 2018 | 09:02 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Congratulations... you just bumped an 11 year old thread.
A P28 ECU won't run a B18B engine in its stock form. It will a B18B with a custom tuned map with the VTEC circuit turned off or disabled. A dual map chip and specialized socket can be purchased from Moates... not that there is any real good reason to "switch" between maps. Join the rest of us in 2018 and get the Hondata s300... then you can upload any map you choose at any time... and get a FAR better system than a basic CROME chip map.
evosix
Engine Management and Tuning
Aug 26, 2016 04:37 AM
Thump_eg94
Jun 25, 2010 12:37 PM
Ls_Turboteg
Dec 10, 2008 07:10 PM
ls-v*2
Aug 12, 2006 07:27 AM
