tranny wont go into gear?
Old Dec 3, 2007 | 10:04 AM
Syk-EG's Avatar
Default tranny wont go into gear?
whats going on guys. i have a problem, i went out last night to have a little fun in the snow , and i stop the car and all of a sudden my tranny wont let me go into any gear. i turn the car off and the tranny goes into gear but when i go to start the car it starts to roll and wont go into gear again... any ideas? thanks
Old Dec 3, 2007 | 10:14 AM
Probot's Avatar
Default Re: tranny wont go into gear? (Syk-EG)
hmm, id start by checking your clutch master cylinder and the slave cylinder
Old Dec 3, 2007 | 10:16 AM
AWD Terror's Avatar
Default Re: tranny wont go into gear? (Probot)
This happend to me once, except there was a long trail of tranny fluid leading up to where I was sitting.
******* around in the snow FTL
Old Dec 3, 2007 | 10:19 AM
Probot's Avatar
Default Re: tranny wont go into gear? (AWD Terror)
no way, ******* around in the snow is a ton of fun!! especially in empty (mall) parking lots.
Old Dec 3, 2007 | 10:23 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Probot &raquo;</TD></TR><TR><TD CLASS="quote">no way, ******* around in the snow is a ton of fun!! especially in empty (mall) parking lots.</TD></TR></TABLE>
It was a ton of fun until the car decide to crap out on me. It was just a beater, so I smashed the gears til I got home.
OP: Anytime you are having trouble with the tranny, the first thing to check is fluid level/age.
Old Dec 4, 2007 | 08:07 AM
Syk-EG's Avatar
Thanx again guys
Old Dec 4, 2007 | 08:16 AM
99GreenEX's Avatar
* B A N N E D *
not too convenient to chekc fluid level on manual when ur in the snow... unless there is some kinda manual tranny dipstick kit i dont know about, if thats the case PLEASE F-ING TELL ME.
Anyway, if u have some space infront of you or behind you, with the car off, put it in gear, then clutch in and try to start, if it moves its a clutch issue, not sure about car codes, so i dont know if EG is cable or hydraulic clutch..
Old Dec 4, 2007 | 08:47 AM
Rock_Star's Avatar
wow... that suck man, hope you get it fix soon. because your missing out on the snow
Old Dec 4, 2007 | 08:54 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: (99GreenEX)
Yes all EG 5-speed engines have hydraulic clutches and no tranny dipsticks.
OP: Does your clutch pedal feel any different?
Old Dec 4, 2007 | 12:33 PM
Syk-EG's Avatar
Default Re: (mcvtec)
No my clutch moves perfectly fine. i told a friend of mine the same thing and he told me that the clutch is not disengaging from the flywheel
Old Dec 4, 2007 | 12:53 PM
tpr's Avatar
tpr
Clutch disc has more than likely come apart and pieces have jammed the clutch disc (whats left of it) against the flywheel
Old Dec 4, 2007 | 02:03 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: tranny wont go into gear? (tpr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tpr &raquo;</TD></TR><TR><TD CLASS="quote">Clutch disc has more than likely come apart and pieces have jammed the clutch disc (whats left of it) against the flywheel </TD></TR></TABLE>
Sounds like you speak from experience.
Just playing.
Old Dec 5, 2007 | 04:59 AM
Syk-EG's Avatar
Default Re: tranny wont go into gear? (mcvtec)
i took advice and checked for any eaks and so far so good, picking up a new clutch soon hopefully that will fix the problem , and i'm back on the road because walking sucks!!
Old Dec 5, 2007 | 03:15 PM
99GreenEX's Avatar
* B A N N E D *
if the clutch truly is fudged, take some damage pics
Old Dec 5, 2007 | 05:38 PM
blk92_d16's Avatar
The PP might have cracked or broke a spring...yes, hopefully the new clutch will do.
Old Dec 6, 2007 | 01:40 AM
v8destroyer's Avatar
i also had a similar clutch problem but i had broken every spring in the clutch disk....
Old Feb 4, 2008 | 05:01 PM
eros906's Avatar
this thread made me feel alot better about my car. im going to take my tranny out 2marrow and inspect the clutch.
btw i drive a 94dx coupe..
Old Feb 4, 2008 | 05:59 PM
BrakeDanceJ's Avatar
Default Re: tranny wont go into gear? (eros906)
Sounds like a clutch, or possibly broken shifter forks.
Rheg6
Transmission & Drivetrain
Nov 23, 2011 11:13 AM
allmotor2.1
Mar 3, 2008 06:02 PM
four-eyez
May 1, 2005 11:59 AM
usdmcrx
Apr 27, 2003 09:13 PM
