Help with remote start, can't find my answer anywhere
Old Dec 3, 2007 | 09:00 AM
C00kiemunstr's Avatar
Default Help with remote start, can't find my answer anywhere
Hello All,
I'm looking for a write up or wiring code or something to help with the installation of a remote car starter. I've been looking for a write up but nothing.... Are there instructions out there? I will be installing it on a 91 civic si.
Thanks in advance
Old Dec 3, 2007 | 09:11 AM
redboy183's Avatar
Default Re: Help with remote start, can't find my answer anywhere (C00kiemunstr)
umm it should come in your box that you bought it with..mine did and it works fine....unless you bought it used
Old Dec 3, 2007 | 09:14 AM
i figure it will come with the wires marked or something, but i was really hoping that someone did a write up with locations of the wires and colour code for the car. I've installed one previously on a different car and found some really good write ups with pictures. Great help.
Thanks for the help
Old Dec 3, 2007 | 10:26 AM
dopey88's Avatar
easy way is with a test light or a multi meter or
12v = white/black
ign = black/yellow
acc = yellow
2nd acc = blue/white
starter = black/white
all wires in ignition harness
tach = blue ( at coil or harness at driver side strut )
brake = green/white (at switch at brake pedal)
that is all you need for a basic install oh and ground but that is easy enough
Ralphie
Old Dec 3, 2007 | 11:59 AM
Default Re: (dopey88)
THANKS, do you know if these wire are easy enough to spot or do i have to dig into the dash a bit? Is the wiring harness just under the dash? fairly visible?
Old Dec 3, 2007 | 12:41 PM
N2HIFI's Avatar
Default Re: (C00kiemunstr)
extreamly accessible, drop the fuse cover and they will be right there at the base of the steering column by the fuse box in black loom
chris
Old Dec 3, 2007 | 12:55 PM
Default Re: (N2HIFI)
thanks for the great help. It looks like i will try to do it this weekend. going to buy a cheep auto start, and put it in. Now question about the tach wire<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dopey88 &raquo;</TD></TR><TR><TD CLASS="quote">
Ralphie </TD></TR></TABLE>
could someone give me a better visual of this wire? driver side strut does that mean under the hood or beside the fuse box with the other wires?
Thanks again.
Old Dec 3, 2007 | 01:01 PM
97grnrs's Avatar
its the blue wire that goes directly into the distributor on the head. trace it back or tap into it there if u want. go to http://64.85.6.121/diagrams/pr...eID=3 .. its all u need
Old Dec 10, 2007 | 04:48 AM
Default 91 civic si auto start install
Hello again,
So this weekend i tried to install my auto start. I installed all the required wired, as stated above, but when i tried to start it, nothing happend.
I programed my remote and when i hit the lock and unlock i can hear the box relay click so i know i got it programmed.
So i'm going to check my box and test my box making sure its trying to start (sending output power). Now my question, There is a 4th wire in the ignition harness, white/red, does anyone know what this is. It gets power with the acc. I did not tough this wire. Could that be my problem??
Old Dec 10, 2007 | 05:21 AM
alscrx's Avatar
Default Re: 91 civic si auto start install (C00kiemunstr)
Constant 12V+ *White* Ignition Switch Harness
Starter *Black/White *Ignition Switch Harness
Ignition *Black/Yellow* Ignition Switch Harness
Accessory *Yellow* Ignition Switch Harness
Tach *Blue* Distributor
Neutral Safety Wire* Green/White* Gear Select Switch
Brake Switch *Green/White* Brake Switch
Trunk Pin *Green/Black (-) *Driver's Running Board
Parking Lights *Red/Black * Fuse Panel or Driver's Kick Panel
Head Lamp *Red/Blue* Fuse Panel
Door Trigger *Green/Red (-) *Driver's Running Board
Old Dec 11, 2007 | 05:48 AM
Well I got it to start, I had to read the instructions........ To start the car i had to push the button twice. Anyways i apreciate all the help. I still have a few more wires to find maybe someone out there who did and install know where to find the wires (or a better place to find them)
I still need to find the door switch. I know its in the centre pillar but i cant get to it. I tried looking along the drivers kick panel but couldn't find it there.
An i would like to hook up the lights, but i wanted to verify first. My autostart sends out a (-) output, I think the head lights use (+) so i can't do it unless i am incorrect?
Old Dec 12, 2007 | 05:00 AM
alscrx's Avatar
I posted a wiring diagram for you..gives you the color of the wire so you can find it
Mrnieves98
Audio / Security / Video
Jul 10, 2016 01:04 PM
DC2 to AP2
Apr 3, 2007 02:26 PM
apm
10
Mar 15, 2005 10:01 PM
Btothe3rdDegree
32
Aug 18, 2004 07:28 AM
