Install CD player
Old Dec 2, 2007 | 06:33 PM
eurowned's Avatar
Default Install CD player
I am going to use the DIY on here to install my after market cd player. I'm only confused on one thing before i take my center console apart. I have a connector that came with my cd player, is that all i need, just "plug and play" with nothing else needed to be done?
heres a pic of what i have:
Old Dec 2, 2007 | 06:35 PM
SuckMyDOHC's Avatar
For the most part, yes. You also need to buy a dash kit to hold in the deck. They go anywhere from 15-18 bucks at stores like best buy or circuit city.
Old Dec 2, 2007 | 06:51 PM
eurowned's Avatar
Default Re: (SuckMyDOHC)
I saw on TI alls you have to do is use some duck tape.
http://www.team-integra.net/se...D=115
Old Dec 2, 2007 | 07:04 PM
jhammond_82's Avatar
Reject Papi
Default Re: Install CD player (eurowned)
thats some in depth stuff it is a pain in the *** to rip out the console, just for a cd player though.
Old Dec 2, 2007 | 07:43 PM
SuckMyDOHC's Avatar
Default Re: (eurowned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eurowned &raquo;</TD></TR><TR><TD CLASS="quote">I saw on TI alls you have to do is use some duck tape.
http://www.team-integra.net/se...D=115 </TD></TR></TABLE>
Thats a pretty ghetto installation. All you need to do is remove the ashtray assebly. From there, you can insert a 1/4" rachet with a 8mm socket to unbolt the radio. Then just pull it out. You might wanna consider getting a small antenna extension. If not, try pulling on your antenna cable reallllllly hard to get it to unclip from the dash metal frame. Then you should have enough length to plug it into your radio. Screw your ashtray assembly back into the dash. Pop in your dash kit, pop in your cage, plug in your harness and antenna, and slide in your deck. Done.
Old Dec 3, 2007 | 04:07 AM
eurowned's Avatar
That sounds a lot easier, i think i might do it that way.
This install seems very straight forward, a lot better then ripping out the center console.
autoxthis
Aug 17, 2007 04:35 PM
EvenStar
Audio / Security / Video
Dec 4, 2006 07:09 PM
Shaguar47
Jul 16, 2006 02:48 PM
92ehatch
Jan 19, 2006 01:58 PM
Junior Carioca
Feb 28, 2004 05:14 AM
