No Heat when at idle
Old Dec 2, 2007 | 06:18 PM
vtec25's Avatar
Default No Heat when at idle
If i am driving or rev to 3k when i'm not moving the heat will blow hot but if i leave at idle it gets colder then just cold. What could this be?
Old Dec 2, 2007 | 06:23 PM
boosstboy's Avatar
Default Re: No Heat when at idle (vtec25)
check your coolant level, engine cold so you dont get burned and make sure the hose is soft and not hard holding pressure before removing the cap.
Old Dec 2, 2007 | 06:36 PM
RockinthEFhatch's Avatar
Default Re: No Heat when at idle (boosstboy)
Make sure your car is warmed up. You can block some of the radiator for winter too
Old Dec 3, 2007 | 04:45 PM
90tegdude's Avatar
Default Re: No Heat when at idle (RockinthEFhatch)
Just to give my opinion as a Toyota tech. And I happen to own 3 integras and a civic hb. I would say it sounds like tour t-stat may be stuck open. Not allowing the coolant to get hot unless the engine is at higher rpms. Caused by the t-stat being open the coolant is circulating during warm-up this should only happen when the vehicle is at operating temp. Try a new one there only about 12 bucks at the dealer. my 90 integra had the same problem last winter t-stat was the fix. BE SURE TO BLEED THE COOLING SYSTEM REALLY WELL AND YO SHOULD BE SET...
Old Dec 3, 2007 | 04:55 PM
manicmechanic's Avatar
t-stat is stuck open. $14+$10 for coolant at the local honda or acura dealership. change it out and bleed the coolent system. tegdude was the one to tell me to change mine out. i agree with him.
Vtec04
Honda Civic (2001 - 2005)
Nov 1, 2017 04:09 AM
richrd0001
May 7, 2015 09:29 AM
oompalumpa61
Jan 8, 2009 03:24 PM
LeArN2LiVe
Nov 22, 2008 12:08 PM
sick4door
Feb 1, 2008 07:07 PM
