Which Head Is PR3-1?
Old Dec 2, 2007 | 04:33 PM
bowdown201's Avatar
Default Which Head Is PR3-1?
B16 right? If so which one like obd1-2 or what. Or is there even a differance?
Old Dec 2, 2007 | 04:35 PM
924doorEG's Avatar
it would be ODII and yes theres a difference
Old Dec 2, 2007 | 04:45 PM
bowdown201's Avatar
Default Re: (924doorEG)
what would the differance be?
Old Dec 2, 2007 | 04:55 PM
924doorEG's Avatar
different years of the motor kinda.....like if you wanted to use a dizzy from a obd1 b16 ona obd2 b16...it wouldnt work the dizzys are different, ecus, wireing harness and stuff like that it possible to use them, you just have to swap out some things
Old Dec 2, 2007 | 05:05 PM
93egSLEEPER's Avatar
Default Re: Which Head Is PR3-1? (bowdown201)
i think that head is from a 00 si.
Old Dec 2, 2007 | 05:26 PM
Frickr's Avatar
Default Re: Which Head Is PR3-1? (93egSLEEPER)
pr3-X is just the casting code for a b series head. the number in the X spot has nothing to do for year. i have a pr3-2 on my 92 jdm b16. the only b series that had a different head was the ITR motors and those were a p72 head.
so to anwser your question, the head was used from 88-00. so without a date code, its impossible for us to tell you what it came off of.
Old Dec 2, 2007 | 08:41 PM
geebs's Avatar
Default Re: Which Head Is PR3-1? (Frickr)
ITR motors didnt have p72 heads.
p72 is GSR.
ITR heads are casted same as the b16 head.. PR3..
Old Dec 2, 2007 | 09:35 PM
1988_96hb's Avatar
https://honda-tech.com/zero...07090
Old Dec 2, 2007 | 09:37 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: Which Head Is PR3-1? (1988_96hb)
to tell if it's a b16 or itr head, on the back of where the distributor mounts, there should be a green marking
and you can also tell waht year it is by looking at the top of exhaust runner #4, farthest left numbers
this is an 00 head
Old Dec 2, 2007 | 09:59 PM
bowdown201's Avatar
Default Re: Which Head Is PR3-1? (n1_egsex)
this is what mine says
Old Dec 2, 2007 | 10:14 PM
n1_egsex's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bowdown201 &raquo;</TD></TR><TR><TD CLASS="quote">this is what mine says
that is a 92 eg6 b16a head for sure
mikep7001
15
Jan 9, 2013 09:31 AM
civicda
Jun 23, 2007 10:52 PM
Jankis
Nov 20, 2006 10:55 AM
IT'S ME DAVID
12
Jul 1, 2005 12:13 PM
