92 eg d15b7: No fire at the plugs, plenty of fuel just no fire.
I need some major help. I backed my car out of the garage so that I could get my 750 Honda out to go for a ride. The car was idling just fine and I went to get into it to move it back into the garage and it backfired, then shut off. I turned the key off, then back on and checked the dash. No Cells, the check lights light up and go off just like normal. I tried to start the car, but all it does is crank. I pulled the plugs and checked them. They're fine. I tested the Ignition Control Module, it tests great. The coil is kind of puzzling. When I test it inside the distributor, it tests bad. If I take it out, then it tests ok. Is it a bad coil? The only other thing that I could think that would be causing this problem, would be a bad wire for the ecu to the distributor. All the fuses under the hood and dash are good. Any suggestions?
Hey did u ever find out anything i got the same issue? It sucks .... let me know i did all the same nthought itwas the ecu as well that is my next test....
RomoGuy
Apr 11, 2005 03:12 PM
