92 Integra not starting
Old 01-13-2009, 12:21 PM
92 teggy's Avatar
Default 92 Integra not starting
I just swapped out the b18a1 that the previous owner had hydro locked for another b18a1 and i cant get it to start. We are getting fuel, and we are getting spark to the spark plugs. The engine will crank and crank but it just wont start and i cant seem to figure out why. Any suggestions?
Old 01-13-2009, 12:49 PM
tegman23's Avatar
Default Re: 92 Integra not starting
Are you throwing any codes?
Old 01-13-2009, 01:08 PM
92 teggy's Avatar
the computer isnt throwing any codes?
Old 01-13-2009, 01:13 PM
unrivaled's Avatar
hey 92 teggy have you gone through and rechecked all your connections? take a look at all the grounds,and firing order
Old 01-13-2009, 01:19 PM
tegman23's Avatar
that was my next thing check your grounds..Honda's need to be grounded right or will cause issues like this...also is the distributor a good? was it used on a car before you that started? just because you have spark doesnt make the dizzy good...
Old 01-13-2009, 01:23 PM
92 teggy's Avatar
I have checked that and also had three other people check it
Old 01-13-2009, 01:29 PM
unrivaled's Avatar
92teggy what else did you do to the motor before install?
Old 01-13-2009, 01:37 PM
92IntegraPOS's Avatar
check timing on dizzy set it to full advanced then full retard see if that effects it.
Old 01-13-2009, 01:50 PM
92 teggy's Avatar
I change the timing belt and the dizzy was off a running motor
Old 01-13-2009, 02:04 PM
unrivaled's Avatar
92teggy have you rechecked your timing on the cams?
Old 01-13-2009, 02:18 PM
92 teggy's Avatar
Took it to a shop and had them align the timing, double checked it and cylinder one at tdc is matched to the timing gear markings
Old 01-13-2009, 03:25 PM
unrivaled's Avatar
now this will probably sound stupid but with the cylinder one at tdc and the cams lined up, take the dist cap off and see where the rotor is pointing. for some reason on a h23 swap i did the dizzy was 180 degrees out.
Old 01-13-2009, 03:41 PM
bunnyhatch93's Avatar
This may sound like a stupind question but is the main relay clicking on? I know you said you were getting fuel but r you sure!!!! If so i would check and make sure your grounds r correct and double check all of your connections.
Old 01-13-2009, 06:38 PM
92 teggy's Avatar
Yes the maian relay is clicking on, and i checked the dizzy, it is on one, firing order is 1-3-4-2 clockwise with one being in the bottom left of the distributor and cylinder one is closest to the cam gears correct?
Old 01-13-2009, 07:58 PM
Paul1985's Avatar
Ignition switch maybe??
Sure your fuel filters good too.. You can obviously hear the pump prime, but hows the filter???
Possibly need new spark plugs...
I hate having issues like this lol. Good luck.
Old 01-13-2009, 08:01 PM
unrivaled's Avatar
correct.ok heres a pic of the cam and crank timing i know you said its all lined up just need to be 100% sure that the crank and cams are lined where its at in this pic...how did you check for fuel? did you pull the line going to the fuel rail? and have you tried a different ecu, and finally have you performed a compression test?
Old 01-13-2009, 08:41 PM
94_red_gsr's Avatar
it's got fuel, spark, timing is on ..maybe it's flooded. try putting the pedal to the floor, hold and crank it until it fires.
Old 01-13-2009, 09:24 PM
92 teggy's Avatar
I pulled the fuel rail and checked to see if the injectors were spraying and they each primed then sprayed in order with the firing order, that picture does look slightly different than my gears so ill double check that tomorrow, i havent compression tested yet cause i cant even get it running and i know its not at all accurate on a cold engine, but that is next on my list of todo things
Old 01-14-2009, 04:17 PM
3gludeb20si's Avatar
i am having the EXACT same problems with my 91 with an LSV swap.. i tried everything and just ended up bringin it to a shop..there in the process of figuring it out right now... g/l
Old 01-14-2009, 05:28 PM
Oreo-TeCk's Avatar
make sure all 3 of your major grounds are tight....its a small thing but a big headache but check ur ecu fuse that located in the engine bay... in the manual it has prossible trouble shooting for cranking but not starting issues
Old 01-14-2009, 06:23 PM
delbert's Avatar
good luck i hate problems like this.
Old 01-14-2009, 09:06 PM
92 teggy's Avatar
The three major grounds are one on the tranny, one going to my thermostat housing and another going from the valve cover to the radiator right
Old 01-14-2009, 10:31 PM
Oreo-TeCk's Avatar
try to ground the head to the radaitor support rather than just the valve cover...check ur ecu fuse but yea those r the 3 major grounds
Old 01-15-2009, 09:35 AM
MooMoo75's Avatar
Teggy - I have the exact same problem with my 92 LS. When you figure out what it is, let me know. I'm afraid I'll have to break down and take it to the dealership!
Old 01-15-2009, 09:47 AM
unrivaled's Avatar
moomoo75 have you checked everything i have listed earlier in the thread?
Quick Reply: 92 Integra not starting
