need help with my future setup
i own a 1.8L B-Series DOHC integra and i have an idea on wat direction to go but i need to get the right parts i dont wana go completely insane hp, but i wana beat at least a mustang. so i got camchafts, cam gears, headers, short shift and exhaust. i need high compression pistons, street strip cylinder head porting, bigger injectors, bigger throttle body, intake manifold, crane valve springs, stand alone management system, and possibly a turbo. is this a good idea? where can i get the parts? how much? thanks
first off DONT go turbo with high compression pistons or else you wont be beating anything after a very short time... and as jhammond posted those are some sites that i got my stuff from and i have a fully built ls turbo...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_RS »</TD></TR><TR><TD CLASS="quote">i need high compression pistons, street strip cylinder head porting, bigger injectors, bigger throttle body, intake manifold, crane valve springs, stand alone management system, and possibly a turbo. </TD></TR></TABLE>
sounds like a quote that should have been in the fast and the furious
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_RS »</TD></TR><TR><TD CLASS="quote">great thanks, so ill just use stock pistons or wat else'll do the job?
what will do the job?
lower comp pistons
you can use stock but regardless you will need good engine management
lower comp pistons
i have 8:1 comp pistons in my ls but im also fully built, bored and sleeved and running huge boost... if your just doing those things and maybe a lil more, you could get away with stock compression but i would get new ones any way... if you want big boost then you will need the lower comp pistons as graf-fiti said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls19integra95 »</TD></TR><TR><TD CLASS="quote">i have 8:1 comp pistons in my ls but im also fully built, bored and sleeved and running huge boost... if your just doing those things and maybe a lil more, you could get away with stock compression but i would get new ones any way... if you want big boost then you will need the lower comp pistons as graf-fiti said</TD></TR></TABLE>
yeah i dont wanna run a lot of boost, so i was thinkin to go all motor and see how much HP i can get. if i do that im also gonna get single throttle bodies... if i go this set up am i missin anything essential in my list? tnx for the help man
