my idle keeps jumping up and down on my type-s
Old Dec 1, 2007 | 05:25 PM
dc5RickK20's Avatar
Default my idle keeps jumping up and down on my type-s
well yesterday i changed from a cold air to a short ram intake and after that my idle keeps jumping up by itself between 2-3k. im running RBC and a stock throttle body and also some of the wires to my tps are extended kinda crappy what do you guys think is wrong? im not seeing any error codes on my k-pro and its idleing high when the throttle body is closed. vaccum leak maybe? i need some help i need my car fixed asap
thanks
-Rick-
Old Dec 2, 2007 | 12:57 AM
risktypeS's Avatar
Default Re: my idle keeps jumping up and down on my type-s (dc5RickK20)
sounds like the crappy job done on the tps with the extended wires you speak of. Maybe you should correct that wiring issue, that might be your problem. If that doesn't fix it check your IACV (Idle Air Control Valve) it's right under your throttle body. Take it off and clean it out.
Old Dec 2, 2007 | 07:58 PM
20civic03si's Avatar
check your idle control valve
Old Dec 3, 2007 | 07:19 AM
blueshark123's Avatar
Default Re: (20civic03si)
Why were your tps wires extended? There is no need for that. What tb adapter are you using? Did you apply permatex to the holes where the bolts go through in the adapter this may be your problem if you didnt.
chawski
Honda Civic (2001 - 2005)
12
Oct 10, 2012 05:12 AM
g0tgot
Feb 1, 2009 07:27 AM
slo_ej8
May 21, 2008 08:44 PM
DAchiko
Nov 12, 2007 06:43 PM
EMphaticONE
Jun 25, 2005 06:26 PM
