Engine Knocking>after ECU chipped Kenji
Old Dec 1, 2007 | 04:33 PM
Rishiras's Avatar
Default Engine Knocking>after ECU chipped Kenji
Guys,
I ordered a P28 chipped for my JDM ITR 99, with I/E/H
I got it from Kenji, all ok.
Now that i installed it, it knocks a lot.I took it out and put oem p73 back.
Kenji told me aslong as our gas here is 91 octane it should be ok and not Knock.
I am in Curacao, here they sell "95 unleaded",but a lot of people here think and say that our gas is very bad, not to be compared to any gas in the USA,Europe etc.
I have no doubt about ECU, kenji is the man for this, I think its my fuel,but want to get some opinions ofcourse.
What do you guys recommend , i am at 18 degrees timing, which was ok for this ECU as well.
1> Try this with Racing fuel C112,C117 or 103, Which i can get VP fuel here on island
Regards,
Rishi
Old Dec 1, 2007 | 04:35 PM
JjuuN R's Avatar
Default Re: Engine Knocking>after ECU chipped Kenji (Rishiras)
C112 and C117 on a stock motor? LOL Try the 103 first, if you still have the knock with that fuel then I don't know what to tell you.
Old Dec 1, 2007 | 05:46 PM
Kavehman's Avatar
Maybe power fc would have been a better choice for you ?
Old Dec 1, 2007 | 05:54 PM
MOVE OVER's Avatar
Default Re: (Kavehman)
I would set the distributor back to 16* and see if that helps.
Is it doing it all the time, at idle, full throttle or where?
This is the problem with using base maps and not a tune.......... You never know how it is going to act on your motor.
Old Dec 1, 2007 | 07:03 PM
J.Berta's Avatar
I agree w/ him ^^^^. 16 degrees. Why dont you get a reprogrammable fuel controller like the FC,Hondata,etc. were you can tune for your air quality and gas quality. It would be alot better than a base map from someone thats not there.
Old Dec 1, 2007 | 07:29 PM
phearable's Avatar
Default Re: (MOVE OVER)
[QUOTE=MOVE OVER]I would set the distributor back to 16* and see if that helps.
[QUOTE]
+2
Old Dec 2, 2007 | 12:23 PM
Rishiras's Avatar
thanks guys,
will set back at 16, and step 2 try 103.
R
Old Dec 10, 2007 | 04:05 AM
Rishiras's Avatar
Default Re: Engine Knocking;after ECU chipped Kenji (Rishiras)
Guys,
ECU is perfect upgrade, my pumpgas fuel was old in tank, i drained it, and filled with new pumpgas, all ok never knocked again.
With 103 , ecu works much agressive, again much much power gain.
Regards,
Rishi
Rishiras
Dec 10, 2007 04:06 AM
delsollove
Jun 10, 2007 07:02 PM
PanamaVTI
Oct 9, 2003 02:34 PM
tc
10
Apr 23, 2003 06:06 AM
PROFILE EK4
Jun 25, 2001 12:26 PM
