how to diagnose swapped jdm b16
Old Dec 1, 2007 | 02:36 PM
rick97civic's Avatar
Default how to diagnose swapped jdm b16
i have a 97 civic w jdm b16. check engine light has been on for a year but whenever i've had a scan tool hooked up it says "cannot connect to blah blah" and doesn't recognize the vehicle. we had to use the obd1-0bd2 conversion harness with the pr3 ecu....now how the hell can i get the codes out of this bitch???
Old Dec 1, 2007 | 03:19 PM
EF9status's Avatar
Default Re: how to diagnose swapped jdm b16 (rick97civic)
It's a 97 civic and you want to check the codes with a PR3 ? Good luck with that the check engine light on the obd2 can only be checked with a scan tool check your fuses there is a pin that transfers the date to the diagnostics equipment.
Old Dec 1, 2007 | 03:48 PM
boosstboy's Avatar
Default Re: how to diagnose swapped jdm b16 (EF9status)
actually there is a check connector 2pin blue or geen on pssenger side above ecu on that harness, use a paper clip to jump them, turn key on and you will get flash codes. you would need a obd2 ecu in the car to read with a scan tool set up for the obd2 type connector on vehicle.
Old Dec 1, 2007 | 05:11 PM
SIred91's Avatar
Rainman
Default Re: how to diagnose swapped jdm b16 (boosstboy)
Any of you noobs realize that this is the 88-91 civic/crx forum?
Old Dec 1, 2007 | 08:19 PM
VtecSyndrome's Avatar
Default Re: how to diagnose swapped jdm b16 (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">Any of you noobs realize that this is the 88-91 civic/crx forum?</TD></TR></TABLE>
I was wondering if anybody else was gonna catch that
Old Dec 2, 2007 | 08:15 AM
alscrx's Avatar
Default Re: how to diagnose swapped jdm b16 (VtecSyndrome)
EK forum will get more replies
Old Dec 8, 2007 | 08:57 AM
Default Re: how to diagnose swapped jdm b16 (alscrx)
sorry, i didnt even notice that myself. but thanks for the input anyways.
Old Dec 11, 2007 | 07:58 PM
StorminMatt's Avatar
You could try to short out the service check connector under the dash on the passenger side. If the OBDII-OBDI conversion was properly made, it should cause the check engine light to flash the code on an OBDI PR3.
chippinpressure
Engine Management and Tuning
Jan 14, 2010 05:47 PM
boostedjdmdc2
Dec 17, 2007 07:32 AM
Team Protocol
Jul 12, 2007 05:57 PM
gsrhatch1126
Jul 5, 2005 06:45 PM
mrduque
Jun 12, 2002 12:01 PM
