1988 Civic Wagovan Shift Problem
Hi all, I have an '88 Civic Wagovan (4WD), manual transmission with about 135k. It has always shifted fine except recently (last week or so) the gears would stick a bit while shifting into them. It felt like the clutch had a little trouble getting all the way to the floor, but I thought it was just getting old and was sticking because of normal wear. Today on the way to work though, I went to shift and nothing happened. I put the clutch in and it wouldn't go into any gear. This went on for about 30 seconds and eventually I got it into 2nd and then 3rd. I was very close to work and parked the car then.
A couple hours later I went out and it shifts fine (with a little sticking going in). I drove it around the parking lot and it did fine in all the forward and backward gears. My question is - what is my best first course of action. I don't know how to check transmission fluid. Is the car safe to drive to the shop? Any thoughts or suggestions are certainly appreciated!
Thanks,
Josh
Thanks,
Josh
Jul 22, 2001 11:15 PM
