Problem with reverse.
Old Aug 16, 2004 | 11:37 PM
SocalChris's Avatar
Default Problem with reverse.
At first I had a TON of trouble getting the car into reverse...and then I got it in, and from there on, it wasnt a problem getting it INTO reverse. But when I try to get it out of reverse it gets stuck really bad, and i have to put a LOT of strength into it to get it out. It goes into reverse fine, out of reverse is another story. What could be the cause / solution of this?
I have a 94 Civic hatch CX.
any help is appreciated.
Old Aug 16, 2004 | 11:38 PM
jdmsiR20's Avatar
Default Re: Problem with reverse. (SocalChris)
you having problems with your clutch?
i know on my friend's gsr, the pressure plate and shift work wouldn't let him shift in/out of a couple of gears. my hunch was correct as we pulled the tranny and pp and disk were shot.
Old Aug 16, 2004 | 11:43 PM
jdmh22eg's Avatar
Default Re: Problem with reverse. (jdmsiR20)
try draining fluid and put some GMC syncro mesh manual trans fluid from chevy....had the same prob and it worked for me
SocalChris's Avatar
Clutch seems to be fine. Its basically just reverse. 1st gear goes in VERY easy too...i can barely feel it go in, and sometimes when i think its in, its not. And i have to pull it out and push it back in for it to engage. I can't even feel it go into 1st gear. 2nd through 5th are fine though.
Old Aug 16, 2004 | 11:44 PM
SocalChris's Avatar
Default Re: Problem with reverse. (jdmctreg93)
Thanks Ctreg, i'll try that.
95sihb's Avatar
Alot of people have been having problems with getting there cars into gear , and most find that it's there shift fork....if you look up shift fork you will see a d.i.y on how to fix that
Old Aug 17, 2004 | 12:15 AM
civtegra_hybrid's Avatar
if its only doing it in rev. then it's your tranz, or if your lucky it could be you shift linkage, if you ran over anything lately, but if not it's the trans
Old Aug 17, 2004 | 12:40 AM
Chicano's Avatar
Default Re: Problem with reverse. (civtegra_hybrid)
I had that problem with old my 92 cx, it would get stuck in reverse every now and then and I would have to tap on the break and let off it to get it back into first...never really knew what the problem was.
nmb16a
Transmission & Drivetrain
Jan 31, 2010 07:43 PM
BlueStar
Jul 26, 2008 07:14 PM
TheAccordGuy
Jan 7, 2008 11:40 AM
aznxenon
Aug 8, 2005 02:12 PM
JdmFront619
Nov 7, 2003 03:03 PM
