tranny gurus. is the b16 countershaft same as gsr countershaft?
Old Dec 1, 2007 | 11:24 AM
building boost's Avatar
Default tranny gurus. is the b16 countershaft same as gsr countershaft?
need to know. i know it each countershaft has the same amount of teeth. and both spin freely when used vice versa with their ring gears. but are they in fact the same countershaft? thanks in advance.
Old Dec 1, 2007 | 03:24 PM
b18bEKcoupe's Avatar
for stuff like this i usually go to http://www.acuraautomotiveparts.org and find the part. Then i take that part number and compare it to the part on http://www.hondaautomotiveparts.com and see if they match.
Modified by b18bEKcoupe at 9:41 PM 12/4/2007
Old Dec 1, 2007 | 05:12 PM
Hybrid96EK's Avatar
Default Re: tranny gurus. is the b16 countershaft same as gsr countershaft? (building boost)
I know they are interchangeable. I would be shocked to find out they didn't share the same part numbers.
Old Dec 2, 2007 | 09:06 AM
96 GSR-T's Avatar
I asked this question a while back and didnt get much either, I do know they can be swapped as long as the matching FD is used, you cant use the GSR FD on the B16 Countershaft and vice versa.
Old Dec 3, 2007 | 09:39 PM
Default Re: (96 GSR-T)
bense said they are the same countershaft.
Old Dec 4, 2007 | 06:42 PM
B16 Part Number: 23221-P21-020
GSR Part Number: 23221-P21-020
Yep. They look to be the same.
LBP
Transmission & Drivetrain
Apr 21, 2013 08:29 PM
igorka_91
16
Aug 18, 2010 01:22 PM
b20vcrxsir
Aug 3, 2008 06:35 PM
SikofFalln
Jun 1, 2008 12:42 AM
Ransom
Mar 15, 2004 09:19 PM
