need some help
Old Dec 1, 2007 | 11:17 AM
umair's Avatar
Default need some help
i was driving my car today and noticed that the belts started to squeak right when i pulled over the battery light came on. i opened the hood and saw that the power steering belt was not on(it was starting to eat away) and the alternator belt went behind the crank pulley. i tried to put the alternator belt on but only half of it got on. i cranked the car and it got back on and drove home with no problems. what would cause something like this to happen?
does this have anything to do with it? this happened about 1000 miles ago but the car has been running fine.
i hope this is not the problem.
Old Dec 1, 2007 | 11:22 AM
DrewMD's Avatar
Davis Photography
I would check the tensioning on the belt. If it was loose, I could see it sliding off like that.
Old Dec 1, 2007 | 11:53 AM
JDM_Frijoles's Avatar
Default Re: (DrewMD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewMD &raquo;</TD></TR><TR><TD CLASS="quote">I would check the tensioning on the belt. If it was loose, I could see it sliding off like that.</TD></TR></TABLE> X2
Old Dec 1, 2007 | 12:25 PM
umair's Avatar
but why would they come off at the same time? but i will tension them some more.
Old Dec 6, 2007 | 02:09 PM
umair's Avatar
bump!!
Old Dec 6, 2007 | 04:23 PM
instrument's Avatar
i have no idea what we're supposed to do with the picture and info you posted.
is that a robotic nipple?
Old Dec 6, 2007 | 04:25 PM
umair's Avatar
that is the crank(the part where the key goes)
Old Dec 6, 2007 | 04:27 PM
blk92_d16's Avatar
Make sure the crank isn't wobbling and that the crank bolt is TIGHT! Then adjust the accessory belts...
B20vEf9
Jun 29, 2010 09:45 AM
dj-t
Jun 25, 2009 08:21 PM
tigueremalo
Jan 24, 2007 08:10 AM
flatblack-h22
Aug 17, 2006 05:53 PM
R6E6I6D
May 13, 2005 07:18 PM
