Cam Gears not lining up after timing belt?
Old Dec 1, 2007 | 04:55 AM
00-501itrspec's Avatar
Default Cam Gears not lining up after timing belt?
hey everyone , we were changing my timing belt and tentioner , and when we went to put it on and line up timing , something seems off, i have skunk 2 stage 3 cams , and aem cam gears , i reset them to 0 , its not that ,
so when i put pins in the cams to hold them straight , it seems the timing is off on the cam gears ,
Has anyone had this problem with the cams or gears? mabye they are a little defected , mabye i am ? either way , any advice would help , thanks in advance for your help ,
Im currently at home , but im going to the garage in a little while and ill find out exactly where we are at , and ill have some pics if needed ,
PS. info needed asap , were just sittin here dumb lookin at this , so help pleazzzzeee i wanna drive
Old Dec 1, 2007 | 07:12 AM
ithrowpoop's Avatar
Default Re: Cam Gears not lining up after timing belt? (00-501itrspec)
pm sent.
Old Dec 1, 2007 | 10:12 AM
SYTFU Tommy.'s Avatar
has the head been milled before? if so, the cam gear markings will not line up correctly
Old Dec 2, 2007 | 11:33 AM
Default Re: Cam Gears not lining up after timing belt? (SYTFU Tommy.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SYTFU Tommy. &raquo;</TD></TR><TR><TD CLASS="quote">has the head been milled before? if so, the cam gear markings will not line up correctly</TD></TR></TABLE>
yeah totally forgot the block is sleeved , therefore its also decked , so is my head , makes sense now , thanks to Brian (ithrowpoop) for tha grommets for my valvecover ,
anywya we started her up and she sounds good, looks like ill be driving my car this winter
ZXRider
Dec 19, 2006 02:43 PM
cooteg6
May 9, 2006 03:12 PM
mtwnfabrication
Aug 10, 2005 12:03 AM
1998HondaCivicLX4dr
Nov 27, 2004 05:10 PM
PhazedSI
Sep 19, 2003 06:54 AM
