vtes doesn't work.
Having a problem with a 90 b16 4door. Vtec does not work. No codes, car runns just fine. It I've tried changing the solenoid, switch, good oil pressure, ecu's, and even running a straight wire to the solenoid. rywire did the harness(never had a problem with there stuff) and car is obd1.
If I run a straight wire to the solenoid it should manually engage vtec, right? I've owned a several EF's and lots of hondas? Kinda confused.
