My lude sounds like a helicopter at 30mph, and vehicle shakes.
I checked for play in the ball joints and I got nothing. I have also read that it may be because my tire needs balanced. I want to know what the problem is before i take it to honda because to me it sounds like my wheel bearings. The sound is only coming from the driver rear wheel at speeds above 25mph. Hopefully someone has had the same issue and you can tell me what I need to do to fix it!
what kind of noise? its probably not a bearing, i bet if you look at the CV boots on whatever side the problem is on there will be a ripped one and sling all over the wheel or tranny housing. if not, unbalanced wheel, MAYBE bad wheel bearing, loose tie rod end those can all make your wheel shake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_93vtec »</TD></TR><TR><TD CLASS="quote">ya it might be unbalanced wheel. do you have stock rims? </TD></TR></TABLE>
No I have 17" aftermarket rims.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude »</TD></TR><TR><TD CLASS="quote">what kind of noise? its probably not a bearing, i bet if you look at the CV boots on whatever side the problem is on there will be a ripped one and sling all over the wheel or tranny housing. if not, unbalanced wheel, MAYBE bad wheel bearing, loose tie rod end those can all make your wheel shake.</TD></TR></TABLE>
It is the rear wheel, so it can not be the CV boot. I also check for play in the wheel by jacking up the car and pulling the tire from side to side but there was no play. So the only two thing it can be is unbalanced or the wheel bearings.
If it wear the wheel bearings would'nt it sound that way all the time?
being an aftermarket wheel, Id have the two rears rebalanced. wouldnt hurt anyway. A wheel bearing can make itself known at one speed first, then get worse. Could be either. BUT, seeing how your car shakes as well, its most likely an unbalance, or one of the cords in your tires shifted.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlyingDaggers »</TD></TR><TR><TD CLASS="quote">could be a real helicopter flying over u making ur car shake n sound like a helicopter......sometimes ur environment can play tricks on u....</TD></TR></TABLE>
Maybe the goverment is tracking me making sure I don't give away secrets from Iraq by flying this helicopter over me all day and night!
No need for anymore sarcasm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18LS »</TD></TR><TR><TD CLASS="quote"> BUT, seeing how your car shakes as well, its most likely an unbalance, or one of the cords in your tires shifted.</TD></TR></TABLE>
You were right!
You were right!
could be...who knows...one day..bam!!!!....FBI at ur front door....fawking u in everyway shape and form....by the time u realized....they knock everyone in ur family---
Jamezvtec
Honda Civic (2001 - 2005)
Jun 11, 2009 04:43 PM
