90 Civic, need some rear suspension dimensions...
So I just bought a Back 90 civic Si with a B16, its my first honda after coming from VW's... anyway it looks like it was maybe slid into a curb at some point, and the right rear control arm was bent, as was the lower mount that it mounts to. It has been repaired, but wasnt aligned and the right rear tire has some positive camber right now (not much but noticeable). So I wanted to get measurements on the two lower bolts that hold the rear arms on. The bolts im looking for are the ones that bolt in from the back, that a lower tie bar would bolt to. I need like a center to center distance apart measurement to see if the one that was repaired is in the right position. Also is there alot of rear adjustment in these cars? im hoipng its straight and I dont have to go back into what they did and pull it or cut it off and start over...
thanks
Chris
thanks
Chris
took it to the alignment shop today. the lower mount is bent, maybe 3/8"? Not sure really... If someone could maybe run out to thier car and take a quick measurement that would be sweet, thanks....
InTheZoneAC
Suspension & Brakes
Mar 9, 2019 05:02 AM
Purple-skunk
Mar 12, 2009 08:03 PM
