Clutch has no pressure...HELP
So..I woke up one morning, get in my car to go to class and my clutch has like little to no pressure when I press on it. I still got to class but I had to force to get into gear.
Tried bleeding the clutch today and now I have no pressure at all. Switched up the slave cylinder and still nothing.
Any ideas?
Any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">clutch master cylinder is possible</TD></TR></TABLE>
Ditto
Ditto
Can you start your car in neutral and then put it into gear while its running? If not then you could have a bent or broken spring in the center of your clutch. (Not sure what that part is called)
If its not that.... then its most likely your clutch master cylinder. I had to replace all of that not too long ago. I bought new lines, clutch master cylinder, and slave cylinder. Man was I psyched when my mechanic told me it was the spring in the center of my clutch! Luckily it was still under warantee by like 3 weeks!
But anyway man, good luck figuring out whats wrong. Keep us posted!
JDMswagSerf
Dec 10, 2013 09:47 PM
Honduh Uhcord
Oct 15, 2007 08:29 PM
vlc92189
Nov 6, 2006 08:49 AM
