can I start engine without axles installed?
this seems like a dumb question on my part, but Im going to do my first swap/build today. I was just thinking that when I drop my new motor in Id like to fire it up before putting every little piece together just to make sure there's no major issues that need to be addressed. So, can I fire it up without the axles installed?? I dont see why not, but maybe Im wrong.
Don't let the trans run too long without trans fluid. I'd just start it to make sure it starts, then shut it off.
We actually made a starter holder from a junk transmission by cutting all the material around the bell housing except the part that holds the starter on. We can now start an engine without the trans installed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 »</TD></TR><TR><TD CLASS="quote">Even without the trans in gear, if the clutch is engaged, it spins the main shaft.</TD></TR></TABLE>
And I hope no one gets the idea of the having the clutch pedal pushed in the entire time it's on.
ok nevermind thats not why i was asking but thanks for the feed back... would still love to see that pic...
it would be kinda cool to make a universal one to fit other 4cyl.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude »</TD></TR><TR><TD CLASS="quote">but you use the starter to check compression when it is in the car....
maybe im just reading all this wrong</TD></TR></TABLE>
I've never seen an engine stand that allows for mounting of the starter since they hold the engine by the bolts used for the transmission bell housing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHPrelude00 »</TD></TR><TR><TD CLASS="quote">no i mean a dry motor on a stand outta the car to spin it over to check compression</TD></TR></TABLE>
haha sorry 117 i was thinking using your contraption that allows the starter to be mounted, but have the engine held on by say a lift or hoist so its in the suspended in the air then plug 3 cylinders then check one...
just a curious idea i had... like if you were dealing with a bunch of engines and wanted to check them... just thinking way out the box... haha
If that were the case, I'd do a leak down. More informative than a compression test anyway. Neither will yield the best results since the engines should be at operating temp for either test.
yea im wasn't thinking of being able to monitor it's realtime specs but literally just check the compression...thanks 117
pm me pics... still i wanna see what you did...im interested
95GSRBOI
Apr 20, 2008 07:37 PM
