to chip not to chip
Old Nov 30, 2007 | 05:58 AM
r1ch1e's Avatar
Default to chip not to chip
I was debating to send my ecu to phearable to get chipped or not. Can't decide. My motor is stock now with just headers and intake. With the p28. The main reason that I want to get it chipped is to get the check engine light out and its because of my o2 and if I eliminate that I won't have to worry again is that justifiable to getting it chipped? I will be getting it tunned when I get cam, cam gear, internals and a turbo with the hondata s300.
Old Nov 30, 2007 | 08:12 AM
Relic1's Avatar
turning off the O2 sensor on a P28, with an untuned chip would be the same as running through a maze blindfolded.
You're going to get hurt.
The ECU uses the O2 to recalibrate how much fuel it puts into the engine, without it you run directly off the maps. Which is fine if the maps and all the calibrations are perfect. If they're not you can damage things fast.
With just intake and exhaust there is no need for a chipped ECU, the stock maps will be better than any untuned chip.
Fix your O2 problem.
Old Dec 8, 2007 | 06:12 AM
r1ch1e's Avatar
Default Re: (Relic1)
i had an extra ecu. that's why i was asking and yeah what you said does make sense. thanks man
ef9allday
Mar 22, 2013 09:46 PM
wrxya33
Jun 26, 2007 02:13 PM
Equilibrium
Jul 21, 2005 08:41 PM
Combustion Contraption
May 30, 2004 11:03 AM
Projectg2i
Dec 16, 2002 02:30 AM
