Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Malfunction Indicator Light
Old Nov 30, 2007 | 05:55 AM
civic scene's Avatar
Default Malfunction Indicator Light
My malfunction light keeps comin on...took it to the dealer they said my CAI is causing my fuel air mixture to run too rich..and I am on my own...any ideas on what I can do?? ...and does ne 1 kn0w anything abt the readiness codes??
Old Nov 30, 2007 | 06:02 AM
IT GUY's Avatar
Default Re: Malfunction Indicator Light (civic scene)
when you installed did you disconnect the battery?
let it idle for 10 minutes or so after reconnecting?
if you only have CAI this is probably your issue
Old Nov 30, 2007 | 06:09 AM
Default Re: Malfunction Indicator Light (IT GUY)
yea the battery was disconnected and I only have CAI..so I guess I'll try that and see what happens..the dealer reset some kind of readiness codes and that took the light off but they won't do it again..do you know anything abt that??
Old Dec 1, 2007 | 10:33 AM
IMALLSLO's Avatar
Seen this many times. For whatever reason the intake causes a rich/lean condition. Wont be covered under any warranty and dont expect them to diag. it again with the intake CAI on.
Rediness codes are set by running test to certain items under certain criteria IE. catalyst,egr etc. If a function doesnt pass a test, it will not set to "complete".
Corksil
26
Apr 14, 2012 12:30 PM
BLKFLSH
14
Sep 29, 2008 06:51 PM
mr devious illusions
Mar 16, 2004 07:49 AM
mntdewred
Nov 18, 2003 05:10 PM
TEK_02
May 23, 2002 04:00 PM
