!!!!2000 Civic Si Not Starting (distributor Problem No Spark) Need Help Asap!!!
hi my Si is not starting at all at first i thought it was the computer i changed it same probelm, then removed the distributor cap to see if rotor is spining and it is. I dont know what the probelm is and i cant get to work or school help asap thanks
MORE THAN LIKELY YOU ARE LOOKING AT MOST COMENLY KNOWN AS THE IGNITOR OR COIL. THOS ARE CHEAP. ALSO IF YOUR LOOKING FOR A EASY WAY OUT CHECK SPARK PLUGS AND WIRES TO SEE IF ONE IS FOULED
Nick Cronk
Apr 20, 2013 06:14 PM
