question on running turbo coolant lines to radiator
Old Nov 29, 2007 | 02:28 PM
.adam.'s Avatar
Default question on running turbo coolant lines to radiator
i've seen a few threads where people are running their coolant lines straight to the radiator. my question is since the coolant system is pressurized, can i have both lines running to the bottom of the radiator and still be good? or should i have one on top and one on bottom?
Old Nov 29, 2007 | 04:15 PM
vestalfootball72
Guest
Posts: n/a
Default Re: question on running turbo coolant lines to radiator (.adam.)
Alot of radiators have coolant lines in the bottom for a auto tranny--
Id tee the coolant feed or return into that-- hope that helps
Old Nov 29, 2007 | 04:18 PM
.adam.'s Avatar
well i have an aluminum rad and was just gonna weld to -an bungs on the bottom.....
Old Nov 30, 2007 | 08:05 AM
.adam.'s Avatar
so im guessing that means i can
Old Nov 30, 2007 | 08:06 AM
PrecisionH23a's Avatar
Default Re: (.adam.)
I looked into doing it this way before then changed my mind. If I recall correctly you will only run one source to the bottom of the radiator.
ashtonallen
Oct 18, 2015 02:11 PM
slammedobd1teg
Jul 8, 2010 07:31 AM
Briang3a3
Jan 17, 2008 10:57 AM
escape2me
Dec 19, 2004 01:29 PM
civic817
Oct 15, 2001 02:12 PM
