*Mini me help*
Old Nov 29, 2007 | 11:49 AM
Joecivic94's Avatar
Default *Mini me help*
Ok so i have a d15b7 block and tranny with a D15b VTEC head..I've had it in my car for a while and I always get a code at 3500 RPM's..Vtec is hooked up and wired right, I think it might be that i need a knock sensor but i read another topic that said the D15b vtec does not have a knock sensor..? I cant check the code because I get the code when im driving and when i stop to check it, it doesnt blink or anything.. So does anybody have an idea what might be up? Thanks if you reply.
Old Nov 29, 2007 | 01:48 PM
92sihbk's Avatar
Default Re: *Mini me help* (Joecivic94)
what is the code for?
Old Nov 29, 2007 | 02:51 PM
Ser1N's Avatar
Default Re: *Mini me help* (92sihbk)
You dont need a knock sensor, they are on OBD2 engines.
and yes what code
Old Nov 29, 2007 | 02:53 PM
Dasfinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joecivic94 &raquo;</TD></TR><TR><TD CLASS="quote">Ok so i have a d15b7 block and tranny with a D15b VTEC head..I've had it in my car for a while and I always get a code at 3500 RPM's..Vtec is hooked up and wired right, I think it might be that i need a knock sensor but i read another topic that said the D15b vtec does not have a knock sensor..? I cant check the code because I get the code when im driving and when i stop to check it, it doesnt blink or anything.. So does anybody have an idea what might be up? Thanks if you reply.</TD></TR></TABLE>
You are definatly not checking your ECU codes correctly...
Check in the FAQ section on how to do it correctly.
OBD1 cars store codes for viewing later, so the slightest flicker of the CEL will be recorded for later use.
Also, what ECU are you running to control that setup?
Old Nov 30, 2007 | 08:23 AM
inline4wHORE's Avatar
Default Re: *Mini me help* (Dasfinc)
what year motor and head are you running and what about the ecu. im running a mini in my del sol and works great it sees 8grand daily but let me know if i can help
Old Dec 1, 2007 | 03:55 PM
Joecivic94's Avatar
Default Re: *Mini me help* (inline4wHORE)
i have a P08 head JDM D15b Vtec, p06 ecu chipped to p08 to match the head.
And i checked the code on the jumper and it wouldnt read.
Old Dec 1, 2007 | 04:40 PM
Dasfinc's Avatar
how are you checking the codes?
If it truely won't read your ECU is dead.
Old Dec 5, 2007 | 04:37 PM
Joecivic94's Avatar
i check them with the blue plug under my glove box, i put a jumper wire in it and watch for the CEL to blink..It does not read the code though.. i have checked other codes before with the same ecu and they all worked. I dont get this code when i turn my key on, i only get it at 3500 rpms and when i shut my car down it dissapears until i get to 3500 again.
Old Dec 5, 2007 | 05:01 PM
Dasfinc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joecivic94 &raquo;</TD></TR><TR><TD CLASS="quote">i check them with the blue plug under my glove box, i put a jumper wire in it and watch for the CEL to blink..It does not read the code though.. i have checked other codes before with the same ecu and they all worked. I dont get this code when i turn my key on, i only get it at 3500 rpms and when i shut my car down it dissapears until i get to 3500 again.</TD></TR></TABLE>
You are reading the codes wrong
*From the "HOW TO CHECK YOUR CODES FAQ" https://honda-tech.com/zerothread/1901557
3) Locate the jumper plug (Civic 92-95 is grey, 96-00 its blue)
For EG, there is 1 tan wire and 1 green
bokals
Jan 20, 2007 11:53 PM
ppl talk bout my old name
Nov 28, 2005 10:27 AM
overclocking1
Apr 8, 2005 05:59 PM
overclocking1
Apr 7, 2005 09:33 PM
TRhatchCRAP
10
Aug 10, 2003 11:52 AM
