did i install this bolt on the short shifter wrong?
Old Nov 29, 2007 | 05:55 AM
vlc92189's Avatar
Default did i install this bolt on the short shifter wrong?
well i dont have pics, but i am pretty sure i can describe it.
with my skunk2 short shifter, you get a bolt that comes with the shifter that goes through the bearin.
well on that bolt you have the the bolt, washer, spacer, axle, axle, washer, then nut in that order.
now m question is when i was puttin the big spacer on, does it go on the non threaded part of the bolt? or the side thats threaded? where the nut goes?
sorry but someone should be ableto help me out! lol
because the tighter i make that bolt the tighter my shifting gets and it gets to the point where i cant shift so i think i put the spacer on the wrong side?
can anyone help?
Old Nov 29, 2007 | 06:07 AM
Probot's Avatar
Default Re: did i install this bolt on the short shifter wrong? (vlc92189)
hmm, i hope i dont get flamed for this - but maybe try putting the spacer in between the last washer and the nut.
Old Nov 29, 2007 | 07:44 AM
vlc92189's Avatar
Default Re: did i install this bolt on the short shifter wrong? (Probot)
thats how it is
Old Nov 29, 2007 | 07:50 AM
Probot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vlc92189 &raquo;</TD></TR><TR><TD CLASS="quote">well on that bolt you have the the bolt, washer, spacer, axle, axle, washer, then nut in that order.</TD></TR></TABLE>
you have the spacer at the end of the bolt??
Old Nov 29, 2007 | 09:44 AM
JDM_King's Avatar
if its to tight then switch the washer around and see how it feels.
Old Nov 29, 2007 | 09:49 AM
sicones's Avatar
Default Re: (JDM_King)
it doesn't matter what side you put the spacer on, with the skunk 2 kit they give you 2 VERY smaller washers, those go against the bearings, and just snug it up it doesn't need to be extremely tight
edit: unless you have a B series shifter with the wider base, the spacer is not needed , it's a universal design
KARSON
Mar 1, 2009 03:04 PM
Gant
Jan 5, 2008 09:54 PM
Extreez
Jan 11, 2007 12:00 AM
themorphious
Mar 7, 2006 09:47 AM
zcivicz
10
Mar 13, 2003 12:02 PM
