Third Gear is Hissing!!
Old Nov 28, 2007 | 05:04 PM
slacks's Avatar
Default Third Gear is Hissing!!
Out of nowhere today, I shifted into third gear and only heard a hissing sound. The tranny is going and my cat. isn't in the best shape, but this sounded insane!
All that would describe the noise is a weird hiss, and it's only while in third gear!
Any input on what this would be?
Old Nov 28, 2007 | 05:06 PM
1sickEJ's Avatar
tranny fluid (lack of)
Old Nov 28, 2007 | 05:29 PM
slacks's Avatar
Default Re: (1sickEJ)
tranny fluid?
wouldn't it do it on all gears then?
side note: my mechanic changed the MT fluid within the last 1500 miles or so.
Old Nov 29, 2007 | 10:10 AM
slacks's Avatar
Default Re: (slacks)
anyone bump for other opinion?
the hissing is inconsistent with the gears so it might be my cat (which has been rattling for a while)
Old Nov 29, 2007 | 10:15 AM
PinoyDelSol's Avatar
* B A N N E D *
im going to have to go with tranny fluid as well, just change it and see if theres a difference.
Old Nov 29, 2007 | 10:16 AM
Probot's Avatar
Default Re: (PinoyDelSol)
if it was fluid it would make a quick grinding noise while engaging the gear...the whining noise is more than likely your input shaft bearing taking a dump on you - time for a new trans
Old Nov 29, 2007 | 10:23 AM
slacks's Avatar
Default Re: (Probot)
my input shaft bearing has been gone for a while (or so i thought) so right now it's most likely demolished.
thanks guys
looks like my suspension work is taking the backseat and my swap is going in earlier than i thought
* B A N N E D *
or maybe your throwout bearing.. Go to search and check out input shaft bearing and throwout bearing! good luck
Probot's Avatar
yea, i had to my suspension dreams in the trunk cause i also just had to replace my trans for the same reason
Old Nov 29, 2007 | 11:51 AM
RYNO48's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slacks &raquo;</TD></TR><TR><TD CLASS="quote">Out of nowhere today, I shifted into third gear and only heard a hissing sound. The tranny is going and my cat. isn't in the best shape, but this sounded insane!
Any input on what this would be?</TD></TR></TABLE>
Your "cat" is fighting off a "snake" and the snake is hissing in defense. I tell you its a jungle out there!!!
Old Nov 29, 2007 | 12:01 PM
99GreenEX's Avatar
* B A N N E D *
tell me honestly what u think a certain gear has to do with your cat.... or input bearing... they do the same thing no matter what gear your in...
Old Nov 29, 2007 | 05:29 PM
slacks's Avatar
Default Re: (99GreenEX)
because the noises are inconsistent
and honestly know nothing about transmissions
but if you have any idea about what is going on, instead of flaming me, then i would appreciate it
Old Dec 4, 2007 | 06:32 AM
99GreenEX's Avatar
* B A N N E D *
i'd say it could be a problem with the shifting mechanism inside, when it slides the collar to lock the gear in place it might be too far, basically the problem i'd say lies between the outside parts of the syncros and the dog teeth geers that lock the 3rd gear in place... or with the shift fork..
and its just common sense that its not the cat or the input bearing if it only does it in one gear... since both those type issues would be consistent with engine speed...
h23vtak
Aug 10, 2007 04:08 AM
20ls01
Aug 3, 2007 10:18 PM
ekdj
10
Jul 13, 2007 07:43 AM
nahledge
Apr 21, 2005 08:39 AM
