z6 and y8 head??
Old Nov 28, 2007 | 05:02 PM
zcrx2006's Avatar
Default z6 and y8 head??
are these two compatible for boost?
Old Nov 28, 2007 | 05:07 PM
Ramma's Avatar
Yes.
Old Nov 28, 2007 | 05:13 PM
slowhitEJ1's Avatar
Default Re: (Ramma)
the z6 in going to flow better though it'll have less compression.. typically the optimal stock head for turboing as it lowers your compression, and has pretty good air flow..
the y8 is going to have higher compression but flow a few CFM's less.. in my case where my compression is TOO low, i'll be using this and a mild port to make up the difference..
either way, i would DEFINATELY look into getting a zex 59300 cam for the z6, or a 105300 for the Y8..
Old Nov 28, 2007 | 06:40 PM
quicksilver1689's Avatar
i ♥ snails
y8 has alot of quench so watch out for total timing it seems to burn really fast so it will need less timing than most d-series heads.
Old Nov 29, 2007 | 07:25 PM
hellakapps's Avatar
Default Re: z6 and y8 head?? (zcrx2006)
z6 all the way due to the bigger chamber-lower comp. good luck
94dxt
Nov 3, 2009 02:02 PM
roachsboosted16
Jan 25, 2009 07:41 PM
carlthecrx
Aug 14, 2007 03:18 PM
Mr_Moos
Mar 19, 2005 08:15 PM
99hatch
Feb 1, 2005 08:36 AM
