Jdm B16A Redline
Old Nov 28, 2007 | 12:39 PM
TurboB16A300Hpteg's Avatar
Default Jdm B16A Redline
What do u think Max Rpm i could bring a B16A with a built bottom End N complete stock head,tb and intake manifold have ehad studs n **** n im boosted I here 9200 But I dont no wanted to see what everone else thinks Thank You
Old Nov 28, 2007 | 12:41 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Jdm B16A Redline (TurboB16A300Hpteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16A300Hpteg &raquo;</TD></TR><TR><TD CLASS="quote">What do u think Max Rpm i could bring a B16A with a built bottom End N complete stock head,tb and intake manifold have ehad studs n **** n im boosted I here 9200 But I dont no wanted to see what everone else thinks Thank You </TD></TR></TABLE>
max rpm = where you stopping making power
1. get it tuned
2. get it on a dyno
3. get some spelling and sentence structure lessons
Old Nov 28, 2007 | 12:47 PM
Default Re: Jdm B16A Redline (GRAF-FITI)
yeah i no this but im saying rev wise without hurting nothing what would u say i can go to on the 50 trim i had i stoped makin power at 7900 but with the new full race set up on a gt30R no dyno till summer time
Old Nov 28, 2007 | 12:50 PM
St Jimmy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI &raquo;</TD></TR><TR><TD CLASS="quote">
1. get it tuned
2. get it on a dyno
3. get some spelling and sentence structure lessons</TD></TR></TABLE>
Exactly. Who cares how high it can rev, chances are your going to stop making power before then, especially with a stock head. You need to get it tunned on a dyno and that will tell you your "redline" or more specificly where to shift at.
Old Nov 28, 2007 | 12:52 PM
Default Re: Jdm B16A Redline (St Jimmy)
yes and again my question what do u think u can bring a B16A to Stock redline.... i dont care where it stops making power or not J.W to how high it can rev to
Old Nov 28, 2007 | 01:00 PM
St Jimmy's Avatar
* B A N N E D *
The block isnt the only thing with limits, with a stock head you risk floating a valve anytime you rev over the stock redline.
Old Nov 28, 2007 | 01:05 PM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16A300Hpteg &raquo;</TD></TR><TR><TD CLASS="quote">yes and again my question what do u think u can bring a B16A to Stock redline.... i dont care where it stops making power or not J.W to how high it can rev to
then rev it to 10,000 for all i care, it's not my motor
it can rev as high as you want it to, albeit probably not very safe
Old Nov 28, 2007 | 01:06 PM
this i no n stock redline is what 8500 Correct not use to b16s had a B20 Vtec before and sohc 1.6 312Hp
Old Nov 28, 2007 | 01:08 PM
GRAF-FITI's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16A300Hpteg &raquo;</TD></TR><TR><TD CLASS="quote">this i no n stock redline is what 8500 Correct not use to b16s had a B20 Vtec before and sohc 1.6 312Hp </TD></TR></TABLE>
speek engrish pweese
Old Nov 28, 2007 | 01:18 PM
Padawan's Avatar
Darth ModerVader
If you have a stock head, I would not spin it much higher than 8200 RPM (the stock redline).
il rev it to 10 i dont care! when it blows Build another
Old Nov 28, 2007 | 01:21 PM
Padawan's Avatar
Darth ModerVader
Okay then....
Old Nov 28, 2007 | 03:10 PM
b18LS's Avatar
Default Re: Jdm B16A Redline (b18LS)
[QUOTE=TurboB16A300Hpteg]il rev it to 10 i dont care! when it blows Build another
Rev it to 14,596 RPM, but NO more
Please dont give honda guys a bad name.
Old Nov 28, 2007 | 03:11 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16A300Hpteg &raquo;</TD></TR><TR><TD CLASS="quote">dont care where it stops making power or not J.W to how high it can rev to</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16A300Hpteg &raquo;</TD></TR><TR><TD CLASS="quote">il rev it to 10 i dont care! when it blows Build another </TD></TR></TABLE>
If you already know what you plan to do, why start a thread asking people a pointless question? Since you can apparently build another one anyway, why dont you go rev the **** out of it and let us know when it lets go.
Thanks
Old Nov 28, 2007 | 06:32 PM
Dogginator's Avatar
Daisy... Daisy...
Yeah this is locked but I'll still post. Good luck revving that high with valve float by using the throttle. You can do it if you try: redline third at 8200 RPM and then downshift to second and release the clutch. Your answer regarding the rev limit will quickly follow when the pistons meet your exhaust valves.
peter-ek4
Apr 11, 2008 05:05 AM
honda=sex
Jan 16, 2005 09:25 PM
TyPe_R_GuY
10
Mar 18, 2004 12:38 AM
Greg123
13
Jan 27, 2004 03:41 PM
