B16A stock bottom end rev limit???
94 Del Sol B16A stock motor.... with the fully build head asside what can the stock B16a block hold together up to RPM wise?? can it take 10k?? anyone seem one fly apart and at what RPM?? Thanks
Re: B16A stock bottom end rev limit??? (Greg123)
I've seen 10k, but I'm not sure if it was on a stock bottom end... But with a stock bottom end would you be making power up to that point? You can make any engine rev up real high, but making power up to your redline is the trick. Is your engine a B16A or B16A3? not that it maters, but the Japs got like 10 or so more hp than us Americans
Re: B16A stock bottom end rev limit??? (EF8 ownz u)
You should be able to get as high as you want with the stock block, as long as you don't skimp out on the head/valve train ... that's what's really important for high revs.
Re: B16A stock bottom end rev limit??? (Odiedogcx)
you stress the rods bad with 10K rpm pulls, watched a stock bottom end b16 blow when he over revved to 10500, KABOOM wasnt pretty
Re: B16A stock bottom end rev limit??? (b20vtecEK)
I had a 1st gen b16a in a crx with a fully ported and built JG Pro Series head. With some custom JG Cams I was able to rev to 10k rpm. This was on the stock block. I misshifted a few times and saw 10.5kRPM on the my auto meter recall.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Odiedogcx »</TD></TR><TR><TD CLASS="quote">You should be able to get as high as you want with the stock block, as long as you don't skimp out on the head/valve train ... that's what's really important for high revs.</TD></TR></TABLE>
I wouldn't go as far as to say that the stock bottom end will go as high as you want it too. I personaly would not skimp out on rods, rod bolts, and bearings when going above 10k.
New User
Re: B16A stock bottom end rev limit??? (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">i took a vx motor up to 9 lol(bent the **** out of a couple valves)</TD></TR></TABLE>
No kidding? LOL
Yeah, I've seen a itr valve train on a stock b16a block handling 10K...
No kidding? LOL
Re: B16A stock bottom end rev limit??? (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 »</TD></TR><TR><TD CLASS="quote">
No kidding? LOL
Yeah, I've seen a itr valve train on a stock b16a block handling 10K... </TD></TR></TABLE>
Whats the point? Its like shooting yourself in the foot? No point. Without modifications, b16's will not make power past 8500 rpm's max. Anything over that is just inviting trouble and completely unecessary!
No kidding? LOL
New User
Re: B16A stock bottom end rev limit??? (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi »</TD></TR><TR><TD CLASS="quote">
Whats the point? Its like shooting yourself in the foot? No point. Without modifications, b16's will not make power past 8500 rpm's max. Anything over that is just inviting trouble and completely unecessary! </TD></TR></TABLE>
Yeah, what's your point? Did I say it produced power up to 10K? Nope.
I was letting the member know the stock block can reach 10K... That's all...
If I wanted to prove it made power I would track down a dyno for you, but for this case I can somewhat (mostly) agree, without modifications it's pointless...
paton5g
15
08-21-2008 04:41 PM
bluesaint
09-02-2006 09:21 PM
SiB16A
01-13-2004 03:13 PM
Skeletor
32
07-09-2003 02:34 AM
