GSR Race motor
Old Nov 27, 2007 | 11:00 PM
JDM_Spec's Avatar
Default GSR Race motor
Hi, im wanting to find out if skunk2 pro series valve springs will work with Jun type 3 without any issue. such as valve eating, or other? any one have exprience with a similar setup? or with Jun 3's
if your woundering what my setup is.
GSR Block
std 81mm CTR PCT Pistons
Balanced crank
ITR Rods
skunk2 Pro Series Valve Springs
skunk2 Pro Series Retainers
skunk2 Pro Series Intake Manifold
skunk2 std Valves
std Gasket
Old Nov 27, 2007 | 11:26 PM
MopdiT's Avatar
Default Re: GSR Race motor (JDM_Spec)
Anyone???
Old Nov 27, 2007 | 11:39 PM
JDM_Spec's Avatar
Default Re: GSR Race motor (MopdiT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MopdiT &raquo;</TD></TR><TR><TD CLASS="quote">Anyone??? </TD></TR></TABLE>
surely someone has a similar setup?
Old Nov 28, 2007 | 04:04 AM
Dogginator's Avatar
Daisy... Daisy...
Search in the All Motor forum as well.
Old Nov 28, 2007 | 07:10 AM
Schister66's Avatar
Man U FTW
What kind of racing are you talking about?? Also, what are your power goals??
Here is the link to the All Motor Forum: https://honda-tech.com/zeroforum/44
Old Nov 28, 2007 | 07:40 AM
all-mtr-teg's Avatar
Damn, CR is gonna be pretty high, is it an all out drag motor?
Old Nov 28, 2007 | 07:51 PM
JDM_Spec's Avatar
Default Re: GSR Race motor (all-mtr-teg)
yes it will be drag and street motor, aiming to be 240whp
Old Nov 28, 2007 | 08:36 PM
K2sInteg98's Avatar
i dont see why they wouldnt work. Also curious to see if you achieve your goal with the stock 81mm
Old Nov 28, 2007 | 08:39 PM
JDM_Spec's Avatar
Default Re: GSR Race motor (K2sInteg98)
my old setup with BLOX HSL cams
blox retainers and valve springs.
skunk2 std intake manifold
stock valves and stock jdm bottom end with 140,000kms made 203.whp
so why not this time around
JDM_EG-R
15
Dec 4, 2011 01:38 PM
jdmkui
Apr 10, 2011 07:37 AM
95civickid
Oct 27, 2008 02:52 PM
AznBlueBoy
Jun 1, 2008 09:26 AM
