Toda Spec C's Or Jun 3's on mildy high comp b16???
Old Nov 27, 2007 | 10:26 PM
tempsohc's Avatar
Default Toda Spec C's Or Jun 3's on mildy high comp b16???
I have contacts that have both Jun 3 camshafts and Toda C's and was wondering which set i should pick up before i go to the dyno.
My setup:
Jdm b16a block rebuilt(deck is milled .004)
p30 pistons(new rings)
stock rods with arp rod bolts
Gsr head milled .004(portflow unit)
skunk2 valvesprings and retainers
buddyclub hi comp head gasket
supertech hi comp valves
Just was wondering which set would best utilize my setup. I am all about drag racing and autocross only comes around once a month so im not too deep into that.
If you have opinions please express why you would go that route or why not...dont just leave open opinions. thanks allot guys.
Old Nov 28, 2007 | 05:05 AM
DA_JDM's Avatar
Default Re: Toda Spec C's Or Jun 3's on mildy high comp b16??? (tempsohc)
From my experience...JUN 3 cams are more design for Top end power In lower gear my performance are almost like my stock b18c block was last year...but in 3rd,4th and 5th gear its a different story
Old Nov 28, 2007 | 10:18 AM
tempsohc's Avatar
thanks anymore...........?
Old Nov 28, 2007 | 02:23 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (tempsohc)
Toda C's are way to much cam for that little b16a the way it's built. June 3's will work better. I would look more at the Toda A's, Skunk 2 STAGE 2, RM m21 cams. All proven to perform very well with an engine like yours and it's intended use.
Old Nov 28, 2007 | 02:47 PM
DA_JDM's Avatar
Default Re: (00Red_SiR)
True...To use the max out of JUN 3 you need high compression, ported head and so on
Old Nov 28, 2007 | 06:57 PM
tempsohc's Avatar
compression not including the mill on the block came out to 11.2 also not including the high comp valves cause i dont know how many cc's it takes away from the combustion chamber. I would think i'd be alright with either cams.
Toda sells pistons for there camshafts and on a stock bore b16 the pistons yeild a 11.1 Compression.
Old Nov 28, 2007 | 08:57 PM
zap's Avatar
zap
check my thread, JUN3 with PCT slugs.
181whp on a Dynojet. 103mph ET on the 1/4mile runs 13's all day on street tires, EFhatch.
https://honda-tech.com/zero...age=3
Old Nov 28, 2007 | 10:27 PM
tempsohc's Avatar
wow you got a sick ride Zap.....was wondering what your thoughts are about the endyn bumpstix...i can buy a brand new set of bumpstix for 100 bucks more than i am buying the jun3 cams for?
Anyone? thanks for the link
Old Nov 29, 2007 | 12:28 AM
zap's Avatar
zap
dude, get the endyn bumpstix(almost same profile as JUN3), a friend of mine in manila actually made 178whp on the same dynojet, same parts as mine.
Old Nov 29, 2007 | 12:36 AM
tempsohc's Avatar
Almost the same profile doesnt do much for me. I wanna know if thats the last cam i'll ever have to buy. Jun 3's are bad ***. I have had them before but the exhaust cam broke on me.
Old Nov 30, 2007 | 12:35 AM
tempsohc's Avatar
anyone else?
Old Dec 1, 2007 | 08:52 PM
tempsohc's Avatar
anyone with experience....Toda C's in a B16 with 11.2< compression?
Old Dec 1, 2007 | 11:57 PM
RagingAngel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tempsohc &raquo;</TD></TR><TR><TD CLASS="quote">anyone with experience....Toda C's in a B16 with 11.2&lt; compression?</TD></TR></TABLE>
# Thompson Engineering MegaTube intake
# JG overbored 68-64 mm throttle body
# JDM ITR intake manifold
# Hondata sheilded intake manifold gasket
# JUN/Maxim 4-2-1 header
# off road 60 mm test pipe
# Z.SPEED prototype 60 mm N1 racing exhaust
# Z.SPEED cam gears (+2, 0)
# Z.SPEED titanium retainers
# Z.SPEED valve springs
# ITR lost motion assemblies
<FONT SIZE="4"># JUN stage 3 cams, lashed @ .007" in. .008" ex.</FONT>
# Chevron Supreme 10W40 oil
# MSD 6A ignition box
# MSD Blaster 3 external coil
# MSD external coil wire
# NGK R V-Power ZFR7F-11 copper plugs .055" gap
# JDM P30 ECU w/Mugen Group-A 66CC program
# Walbro high pressure 255 liter/hr fuel pump
# B&M adjustable FPR (50 psi no vacuum reference)
# Field SFC-VTEC (-12 -10 -12 -10 2 2 2 2 5500)
Old Dec 2, 2007 | 05:37 AM
tempsohc's Avatar
thanks kinda what i was looking for...i guess jun 3's it is....
Old Dec 2, 2007 | 11:18 AM
b20vtech's Avatar
Default Re: (zap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zap &raquo;</TD></TR><TR><TD CLASS="quote">check my thread, JUN3 with PCT slugs.
https://honda-tech.com/zero...age=3</TD></TR></TABLE>
i saw 165 only
Old Dec 2, 2007 | 03:28 PM
tempsohc's Avatar
thats before he put the header and the type r intake manifold...!....keep it coming
Old Dec 2, 2007 | 03:29 PM
tempsohc's Avatar
Default Re: (b20vtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech &raquo;</TD></TR><TR><TD CLASS="quote">
i saw 165 only</TD></TR></TABLE>
I wish 165 was good for a 13 second run.
Old Dec 3, 2007 | 12:07 PM
b20vtech's Avatar
I wish 165 was good for a 13 second run.</TD></TR></TABLE>
sure u can, on 22" slicks
CrX-WoRlD
Aug 26, 2007 10:27 PM
b20todaej6
15
Nov 9, 2004 08:29 PM
93jdmej1
17
Jun 17, 2004 11:14 PM
vtec94civic
Dec 13, 2003 06:51 PM
gsrvx
75
Jun 16, 2003 05:57 PM
