fuel line question(bolt)
Old Nov 27, 2007 | 07:32 PM
IP RACING's Avatar
Default fuel line question(bolt)
alright I swapped my fuel pump the other day and I ahd left the bolt that goes on the fule pump you know the line that goes right ontop of the fuel pump lose. you know how you have to line the botl hole up with the fuel line. I think I over tightened it so that the fuel isnt properly getting passed through the line. do you think that can make the car bog down at times
Old Nov 27, 2007 | 07:34 PM
alscrx's Avatar
Default Re: fuel line question(bolt) (IP RACING)
If you just did the pump and now the car bogs then yes you should recheck your install.
Old Nov 27, 2007 | 08:00 PM
IP RACING's Avatar
Default Re: fuel line question(bolt) (alscrx)
yea I did the fuel pump sunday and just put in a new fuel filter today a few hours ago but it sounds like the fuel is having a bit of trobule getting to the actualy engine.Im thinking that bolt not being properly lined up might be the answer. what do you think.I know the fuel pump is installed correctly it primes fine just sounds like its restricted a bit. starts first turn of the key. idles good just it bogs down sometimes mainly when its warmed up. you think the bolt not being lined up could make it do that
yakobm
12
Sep 9, 2011 03:49 PM
prietito69
Mar 10, 2008 02:36 PM
JLHDOHC
Feb 10, 2007 08:16 PM
littlebluecrx
Mar 11, 2002 06:43 PM
