i need some help [MAINT REQ.]
Old Nov 27, 2007 | 04:18 PM
superdat1's Avatar
Default i need some help [MAINT REQ.]
so my maint req. light came on a couple of days ago. i have no idea why
what are some of the factors that would cause it to turn on and is there
aynyway i can check to see what it is?
thanks in advance
Old Nov 27, 2007 | 04:21 PM
posHonda's Avatar
Nothings wrong with your car. Its just a light reminding you of when its time to get your maintenence done (every 7500 miles I believe).
Theres a button under the dash near your right knee. Turn the key to the "on" position (you dont have to turn the motor on, but it still works if you do) and hold that button down for a few seconds and it turns right off.
Old Nov 27, 2007 | 04:25 PM
WookinPaNub's Avatar
Default Re: i need some help [MAINT REQ.] (superdat1)
Please use the search button in the future.
https://honda-tech.com/zerothread?id=2143378
Light is just a reminder, nothing is wrong with your car.
Old Nov 27, 2007 | 05:52 PM
ls19integra95's Avatar
Default Re: i need some help [MAINT REQ.] (WookinPaNub)
there was a guy who just asked this the other day... the maintenace required light and the check engine light are two different things... check engine means something it wrong and the maintenance required just means that by your mileage, dealer says that certain things should be replaced, cleaned, etc... if you have your owners manual, in the back it tells you what the dealer says you should do at the milage your at... so if that lights on you have no problems... turn it off by pushing and holding the little button on the driver side underneath the dash next to your right leg and turn key to on position... keep holding till it turns off...
Old Nov 27, 2007 | 06:43 PM
superdat1's Avatar
fer sure. thanks guys
yeahyeah1469
Oct 2, 2010 01:04 AM
whiteteggy94
Jun 16, 2007 08:04 PM
XViEtBoiX
Honda Civic (2001 - 2005)
May 14, 2006 07:22 PM
Brian-Brian
Jun 6, 2003 01:49 AM
crashnburn
Jul 13, 2001 08:39 PM
