Which color hid bulb temperature are you guys using?
Im buying a mcculloch hid kit soon.(with retrofit)
alot of people use oem 4300k but im thinking about getting 5000k or 6000k
undecided
i know the 6000k has blue tint but the 5000k is crystal white.
what do you guys prefer or use
undecided
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 »</TD></TR><TR><TD CLASS="quote">Im buying a mcculloch hid kit soon.(with retrofit)
undecided
5000k will be slightly blue, 43-4500k will be closer. I had 5300ks and they were what i'd call "ice", it was a bluish white. You'd get a better "white" out of an OEM 43-4500k bulb.
I would NOT get a 6000k bulb, i'd get the 5000k if you were determined to not get OEM. You lose light output the higher you go, so 5,000k would be a better balance of color and performance.
undecided
</TD></TR></TABLE>5000k will be slightly blue, 43-4500k will be closer. I had 5300ks and they were what i'd call "ice", it was a bluish white. You'd get a better "white" out of an OEM 43-4500k bulb.
8000k's 8) Diamond Blue
I went for the look rather then the light output. But im happy with the light output. I think the light out put is like 3100 lumens [not sure] and its definitely better than stock halogens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chawski »</TD></TR><TR><TD CLASS="quote">^^4300k are around 3200lm. the 8000s are in the low 2000s</TD></TR></TABLE>
maybe not even 2000. Philips Ultinon 6000K bulbs are rated at 2400 lumens, compared to 3200 for 4100K.
Toshiba HIR 9012 bulbs trimmed to fit a 9006 application probably put out more lumens than an 8000K HID bulb, and they only cost $25 each and draw the same amount of current as a regular 9006 halogen bulb.
Oh yeah, I'm using OEM Philips 4300K D2S bulbs in Hella bi-xenon projectors. The bulbs are nearly 4 years old so I'm sure they have color shifted above 5000K by now.
"Oh yeah, I'm using OEM Philips 4300K D2S bulbs in Hella bi-xenon projectors. The bulbs are nearly 4 years old so I'm sure they have color shifted above 5000K by now. "
I didn't know they color shifted over time.
2002, 2011, accord, bulb, edge, ford, hid, honda, hondatech, kit, recommendations, sitefordedgeforumcom, tech, temp, temperature
