Would a bad distributor seal cause my car to run poorly?
Old Nov 27, 2007 | 01:00 PM
m1ndless's Avatar
* B A N N E D *
Default Would a bad distributor seal cause my car to run like ****?
I was told my distribuitor seal was leaking, I checked it out and they were right.. my car has been driving pretty shitty latley, would this be the cause?
Old Nov 27, 2007 | 02:40 PM
accord99power's Avatar
Default Re: Would a bad distributor seal cause my car to run like ****? (m1ndless)
no, whens the last tuneup you had done if you dont do them?
Old Nov 27, 2007 | 02:43 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Would a bad distributor seal cause my car to run like ****? (accord99power)
I did one about 10k miles ago, if even. I replaced distrubitor cap and rotor, spark plugs, and a few other things..
Old Nov 27, 2007 | 02:53 PM
hows it running shitty? shuttering on acceleration?
Old Nov 27, 2007 | 03:06 PM
m1ndless's Avatar
* B A N N E D *
It feels like its accelerating poorly, like a lack of power, and the engine seems ti run very loud, espically when its cold out.
Old Nov 27, 2007 | 04:08 PM
have you ran fuel injector cleaner through recently? people recommend sea foam on here. I personally havent used it heard its pretty powerful stuff. I use BG's Intake system cleaner and lucas fuel cleaner, have you changed air filter? fuel filter? As far as running loud on cold days not sure for that make sure you dont have an exhaust leak anywhere for that. how many miles on the engine?
Old Nov 27, 2007 | 06:36 PM
m1ndless's Avatar
* B A N N E D *
I will try seafoam in my gastank, air filter should be fine, not sure about the fuel filter, ill check it all out tomorrow morning, thanks!
Old Nov 27, 2007 | 06:44 PM
sony224422's Avatar
is it loud like a ticking? when was the last valve adjustment?
Old Nov 27, 2007 | 09:25 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Would a bad distributor seal cause my car to run like ****? (sony224422)
I hear a clicking noise coming from my right front tire sometimes at lower speeds, it might be just some debris stuck to my tire though, not sure..
I had a valve adjustment done about 1 year ago, should I do that agin?
I need to do whatever it takes to keep this car running for a few more years, I want to put about 1500 into it in the next few weeks so what should I do?
Old Nov 27, 2007 | 09:27 PM
sony224422's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m1ndless &raquo;</TD></TR><TR><TD CLASS="quote">I hear a clicking noise coming from my right front tire sometimes at lower speeds, it might be just some debris stuck to my tire though, not sure..
I need to do whatever it takes to keep this car running for a few more years, I want to put about 1500 into it in the next few weeks so what should I do? </TD></TR></TABLE>
could be a bad CV joint.. do you hear it when turning?
Old Nov 27, 2007 | 11:03 PM
tpot90's Avatar
If you seafoam, go straight to the source!
Put it in the vacuum line that runs from the break booster to the FI.
Old Nov 28, 2007 | 11:42 AM
m1ndless's Avatar
* B A N N E D *
Default Re: Would a bad distributor seal cause my car to run like ****? (tpot90)
More symptoms I noticed today...
Rough Idle, Sputtering when accerlerating, running poorly when cold..
I will change out the spark plugs and such, should I just replace the seal or should I do the whole distributor?
Old Nov 28, 2007 | 05:33 PM
theres an o ring that needs to be replaced not the whole distributor. how many miles on the vehicle?
Old Nov 28, 2007 | 05:42 PM
Slopoke's Avatar
Bad distributor seals can infact cause the car to run poorly.
Bad seals can not only allow oil to leak out and cause a mess, but distributors can leak internally also(oil leaks from the engine and enters the dist through the base). I've seen a few cars run poorly because the internals of the distributor were coated in oil.
If its leaking internally, you will need to replace the distributor.
Old Nov 28, 2007 | 05:50 PM
m1ndless's Avatar
* B A N N E D *
Default Re: Would a bad distributor seal cause my car to run like ****? (Slopoke)
It sort of smells like oil sometimes, thanks Slopoke!
Ill have my mechanic look at it!
Old Nov 30, 2007 | 07:52 PM
PnX-R's Avatar
Hmm.. Did you replace them all with OEM parts from Honda?. I can't tell you how many times I've seen cars come in because they're misfiring and such due to crappy aftermarket parts. I find the usual cfappy spark plugs and wire set along with a crappy distributor cap and rotor. Like I've stated before somewhere... It is said that Honda's and Toyota's are very sensitive when it comes to the ignition system. Thus is why they recommend OEM parts. The last time I had a customer in for this, I charged him an arm and a leg because it was a waste of my time.
Old Nov 30, 2007 | 11:31 PM
bseriescrxsi's Avatar
Default Re: Would a bad distributor seal cause my car to run like ****? (PnX-R)
might be time for a timing belt change
doubleoazn03
12
Sep 5, 2022 09:10 PM
mitchh29
17
Mar 10, 2013 10:06 AM
Jayk00CivicEx
Mar 29, 2012 10:49 PM
92integraVTECgsr
Oct 20, 2010 05:44 PM
SlalomHonda
14
Nov 21, 2005 06:53 AM
